Save big + get 3 months free! Sign up for ExpressVPN today
  1. pcumming's Avatar
    1. Galaxy S6 Verizon Marshmallow load of this site here: forums.androidcentral.com shows blue LOADING box and start up sound
    Whenever I bring up this site with Chrome OR Firefox on Android S6 with marshmallow the screen loads but I have a blue box in the center of screen that says LOADING. See attachment It does not go away. Nor does it load the rest of the screen,
    This happens in both browsers. If I disable pop-ups, same thing.If I request desktop site same thing but in different location.
    This freezes use of the site except for any other buttons that may appear above this message.
    I did clear cache/data and history for Chrome and Firefox
    I did several restarts.
    I did wipe the phone cache.
    Does not matter if Wifi is on or off
    Does not matter if Power saving is on or off
    Thoughts??
    NO big deal . Did not notice same LOADING box behavior yet on other sites.Not sure it happened n Lollipop.
    2. START UP SOUNDS
    Also noticed (not a big deal) that the start up sounds are now gone with Marshmallow. Only can get back by routing I read on XDA forum
    Thanks for any feedback
    Peter
    Attached Thumbnails Galaxy S6 Marshmallow load of forums.androidcentral.com shows blue LOADING box and start up sound-screenshot_20160401-171946.jpg
    04-01-2016 04:24 PM
  2. green mtns rider's Avatar
    I got this as well while looking for a fix for the double lock screen issue i mentioned in another thread.
    04-01-2016 10:08 PM
  3. pcumming's Avatar
    Thanks Green MTN. Nice t know it can be duplicated.
    I also noticed they changed a Chrome setting to enable or disable tabs so that it shows a number of screens open at top right of Chrome. I enabled or disabled (forget this) and it went back to old behavior. BUT now it shows the screens pretty much on top of each other when you go touch the left most button on phone. But you can spread them out with your finger.
    ****Have you noticed the sensitivity of the buttons on screens requiring more pressure now?
    I had my Visual Voicemail go out afterwards and I had to call Verizon which took about 20 mins to correct some how.
    In this version Verizon can actually get into your phone remotely with your permission
    Thanks
    04-02-2016 07:55 AM
  1. Replies: 20
    Last Post: 12-19-2016, 08:40 PM
  2. Replies: 96
    Last Post: 05-30-2016, 10:37 PM
  3. How long should I charge my S7 for when it comes out of the box?
    By AC Question in forum Samsung Galaxy S7
    Last Post: 04-02-2016, 11:35 PM
  4. How much of the screen of the S7 Edge is actually available for use?
    By AC Question in forum Samsung Galaxy S7 edge
    Last Post: 04-01-2016, 09:50 PM
  5. Is the LG G5 capable of wireless charging?
    By AC Question in forum LG G5
    Last Post: 04-01-2016, 04:39 PM
