Voicemail error 9007 you see in pull down menu. Result voicemail dol not show up
How to fix until new Marshmallow release:
Turn off Power Saving mode and it will work fine
Any missed voicemail's will soon show up
You can turn power saving mode back on if desired but will need to turn off if you want to see a voicemail on a call you missed or if you see 9007 error
Voice to Text issues (email and message apps) using certain commands such as "New Line", "New Paragraph".
Will not work if Power Saving is on. It ignores these and prob other commands
No one needs to reply unless they care to confirm.
I posted these on Code Google bug site
Thanks
Peter
Thanks
Peter
