A
AC Question
Galaxy S6 Marshmallow Quick-settings lock
Hi all,
Since the marshmallow update I've been a bit confused regarding the quick settings scroll down menu:
In the past one finger scrolling from the top of the screen would get the notifications plus the quick settings above them, 2 fingers from the top would extend to all the quick settings & zooming with 2 fingers into a specific notification would expand it ro see its content without opening the app..
With the marshmallow update now there seem to be some inconsistency:
Sometimes if you scroll down more with one finger you'd get all the quick settings, sometimes if you place your finger on one of the notifications that you wabt to expand you'd get the notification expanded & sometimes the quick settings will expand to she all the quick settings
What's the deal? How do I get to always expand the content of a notification instead of just causing the quick settings to expand? Very annoying (
Hi all,
