1. emad1995's Avatar
    When I'm in my university connected to their wifi my battery drains like crazy and I'm not sure why. I have confirmed that it's the wifi because when I switch it off for three day my battery drain reduces drastically.
    When I'm at home or friends houses the wifi drains normally but when I connect to the school network it goes off the chain. Is there a solution for this? I don't have a lot of data in my plan so I have to rely heavily on wifi.
    04-17-2016 06:40 PM
  2. Rukbat's Avatar
    The weaker the wifi signal (this also applies to the mobile signal), the more battery is used. It's assumed that if the received signal is weak, the transmitted signal is going to be received poorly (because most paths are symmetrical), so the transmitter power in the phone is increased.
    04-17-2016 07:44 PM
  3. SophiaPetrillo's Avatar
    Only connect to the WiFi when you need it, opposed to keeping it connected continuously. Do you download large files or stream for long periods of time (more so than at home or a friend's house)? Try testing the battery drainage with other devices, just to reaffirm that the WiFi is the direct cause.
    04-17-2016 08:06 PM
  4. emad1995's Avatar
    I normally have full bars of wifi at school
    04-17-2016 08:29 PM
  5. emad1995's Avatar
    It's a huge hassle to keep toggling wifi because there's a chance I might forget to turn it on and then start downloading a huge file. This has happened to me before that's why I'm hesitant. Also, the keep wifi on during sleep is set to only while charging but the issue with that is that it takes too long for the phone to go into sleep. I was writing a 3 hour final today so my phone was in my pocket not being used for 3 hours, it drained from 67% to 40%.
    As for other devices I have a galaxy tab s2 which drains faster when connected to the school wifi as well but that's not as big as a problem for me as is my phone because tab s2 lasts a long time regardless of the drain
    04-17-2016 08:33 PM
  1. Why do my notifications on the lock screen say content hidden
    Last Post: 07-01-2016, 01:52 PM
  2. G4 Marshmallow battery issues
    By JGLdn in forum LG G4
    Last Post: 04-27-2016, 02:07 PM
  3. Replies: 1
    Last Post: 04-22-2016, 08:29 AM
  4. Replies: 1
    Last Post: 04-22-2016, 08:24 AM
  5. I need to chage the alarm tone on my phone
    Last Post: 04-17-2016, 07:50 PM
