1. gia_b's Avatar
    Hello! I have the S6 for a couple of months now and it has never disappointed me - until it's time to take a picture in natural sunlight.
    Everytime I take a photo on a sunny day using Auto Mode, portions of it turn up overexposed and the colours seem washed out, making it hard to distinguish a detailed subject. Even the sunrays get blown out into big streaks of light. Decreasing the brightness seems to have no effect. Otherwise, the camera performs amazingly good under even lighting or artificial light, cloudy days and low light conditions.
    I will attach a few photos to illustrate the issue. They were all taken in Auto Mode with HDR Auto. But even when I switch to Pro Mode and tweak the settings to take another photo in the same place and under the same lighting conditions, the halo effect still stretches over a big part of the picture.
    Problem with the camera. Should I return my S6?-2.jpgProblem with the camera. Should I return my S6?-3.jpgProblem with the camera. Should I return my S6?-4.jpgProblem with the camera. Should I return my S6?-.jpgProblem with the camera. Should I return my S6?-5.jpgProblem with the camera. Should I return my S6?-rhis-too.jpg
    Could anyone tell me if the problem is on my end and I'm incapable of taking a good photo and what cand I do to fix it or should I just return the S6 and replace it with another one? Did anyone else experience this issue? Thank you!
    07-08-2016 02:29 PM
  2. Premium1's Avatar
ID:	231761Click image for larger version.
ID:	231762Click image for larger version.
ID:	231763Click image for larger version.
ID:	231764Click image for larger version.
ID:	231766Click image for larger version.
    Better position yourself. It seems the way the light is shining is always going to give you those types of images.
    07-08-2016 03:00 PM
  3. Dorian Anreiter's Avatar
    I like the lady in your pictures 😊
    07-09-2016 01:43 PM
  4. Gary_Berg's Avatar
    If you have the sun shining directly on the lens you can get flare, which looks sort of like your last shot. But I wonder if you have grease or a fingerprint on the lens. I'd try cleaning the lens with a microfiber cloth, maybe breath on the lens to dampen it slightly. Do NOT use a damp cloth or put water on the lens/phone.
    07-09-2016 05:56 PM
  5. gia_b's Avatar
    Thank you all for the tips, I will definitely try to move around a bit more and wipe the lens everytime. I removed the protective film the day I got the phone, now I will be more careful to have it all clean and see if it makes things better. Honestly, I would have blamed my inability to take a good shot as well, but I compared the samsung s6 with an iphone 5s side by side, taking a couple of pictures seconds apart, and the iPhone definitely had less flare (if any) and the colours seemed more vibrant, too.
    That's what made me think it might have been a problem with the Galaxy S6, since it supposed to be superior in specs to the iPhone. And it is, I must say, in low-light conditions.
    Thank you all, again.
    07-10-2016 06:52 AM
  1. Google Play services not compatible with my device?
    By Leahjean93 in forum Samsung Galaxy Note 3
    Last Post: 10-08-2017, 03:23 PM
  2. Replies: 1
    Last Post: 07-08-2016, 04:16 PM
  3. Replies: 0
    Last Post: 07-08-2016, 02:17 PM
  4. I finally received the Samsung Music update
    By rokemsokem in forum Samsung Galaxy S5
    Last Post: 07-08-2016, 02:01 PM
