1. Bruno Slivar's Avatar
    I received Wireless Charger Pad-YCCTEAM
    Charger look so cool. Blue light. 3 coil for charging.
    I try with case and phone was charging. With none problem.
    The workmanship of the charger is good. The only minor problem is the speed of filling that noticeable after a long time used a quick charger.
    https://www.amazon.com/dp/B01DTSTVGI...cUvbUpU5359296
    08-23-2016 03:04 PM
  2. srkmagnus's Avatar
    Please provide more information with regards to reviewing the device. Such information that would be deemed useful for readers include:
    Do you need to position the device in a certain part of the charger for it to work?
    How long of a cable is provided?
    Are the lights bright and are they a nuisance when you are trying to sleep at night? Some people are sensitive to light, so this would be important to include.
    Additional specifications (e.g. size)?
    Thank you.
    08-23-2016 03:37 PM
  3. Bruno Slivar's Avatar
    Tnx.
    No need position phone on some specific place.
    Cable is 1m.
    When phone is charging, i dont hear anything.
    Blue light is not strong and in dark of the room i cant see on wall or any other place. Just the charger light.
    Size is 10.8*62*122mm
    There are non-slip pads on the top of the charger and on the bottom to keep the charger and your phone from easily sliding off.
    08-23-2016 03:43 PM
  1. Is Total Wireless really so bad?
    Last Post: 08-30-2016, 03:37 AM
  2. Is this Samsung Fast Charger safe to use with my Note 7?
    By felloffthetruck in forum Samsung Galaxy Note 7
    Last Post: 08-24-2016, 06:31 PM
  3. Best car charger?
    By Infamousx14 in forum Samsung Galaxy Note 7
    Last Post: 08-23-2016, 03:27 PM
  4. Replies: 0
    Last Post: 08-22-2016, 04:29 PM
