1. betsybetc's Avatar
    Hi,
    About a week and a half ago I purchased a Galaxy S6. Battery life has been less than stellar but lately has been awful. I looked at my recent battery usage and 38% is attributable to Android System, and 29% is attributed to the Android OS, and 11% attributed to the screen.
    To my knowledge, I don't have anything running in the background on the phone, and have disabled a few applications that I do not use (think google-related, Samsung Milk). Is there a big application that I should be disabling but haven't?
    I am desperate for my new phone to work... When I am charging it and using it, the battery doesn't gain a charge.. things are grim.
    I am not a super technical person but would really appreciate anyone's help or advice.
    Thanks in advance!
    09-25-2016 07:44 PM
  2. Gary_Berg's Avatar
    Try disabling the Facebook app from Settings / Applications. Try installing the GSAM app and see if it gives you any more info. Also, try booting the phone in safe mode and see if it still guzzles power.
    09-25-2016 08:00 PM
  3. betsybetc's Avatar
    Thanks. I'd already uninstalled Facebook. I downloaded GSAM and it was also reporting high IOS usage - when I clicked on Manage it did not list any additional details. I will try the safemode suggestion now...
    09-25-2016 08:28 PM
  4. betsybetc's Avatar
    Just an update in the event anyone has a similar issue... noneeds of the suggestions I found or were told helped... then out of desperation I had to turn on ultra power saving mode for a while.. when I turned it off (and back onto regular power saving mode) my battery stopped draining so quickly. Not sure what turning UPSM on and off did, but it seems to have fixed the problem.
    09-28-2016 03:34 PM
  1. Replies: 3
    Last Post: 02-18-2017, 02:12 AM
  2. How do i fix my lock screen?
    By Stephen Kopercinski in forum Samsung Galaxy S5
    Last Post: 09-26-2016, 03:04 AM
  3. battery spec's - old versus new
    By bialy in forum Samsung Galaxy Note 7
    Last Post: 09-25-2016, 11:40 PM
  4. Replies: 0
    Last Post: 09-25-2016, 07:24 PM
  5. Replies: 0
    Last Post: 09-25-2016, 06:08 PM
