1. mkdon's Avatar
    hi
    samsung repairs have said my motherboard and charging port have water damage and thus are unable to fix it under my warranty. is it worth getting this fixed or is it better to buy a new phone. as it stands the phone wont charge and the phone wont lock and go into standby
    02-05-2017 01:28 PM
  2. Who884l5's Avatar
    Depends on how much it costs to fix. If its cheaper to fix it then fix it. If not get a new phone.
    02-05-2017 01:30 PM
  3. mkdon's Avatar
    is this normal for mobile companies to not honour warranty if the phone has suffered water damage even if its not through ones one doing? i could understand if i had drop the phone into water or something but nothing of the sort has happened
    02-05-2017 01:55 PM
  4. IAmSixNine's Avatar
    So your saying the liquid damage happened during manufacturing?
    It had to be someones doing as i dont think they add water when the units are made.
    pontiac005 likes this.
    02-06-2017 10:49 AM
  5. bksalt's Avatar
    Well put
    02-06-2017 06:27 PM
  1. Otterbox causing my S7E to overheat and shut down apps
    By Alanin502 in forum Samsung Galaxy S7 edge
    Last Post: 02-08-2017, 12:42 PM
  2. Replies: 3
    Last Post: 02-05-2017, 09:31 PM
  3. Why can i only just hear my sat nav and phone
    Last Post: 02-05-2017, 09:30 PM
  4. Samsung Galaxy J3 2016: apps on SD card, and software info?
    By garisa in forum Samsung Galaxy J Series
    Last Post: 02-05-2017, 11:30 AM
  5. Replies: 1
    Last Post: 02-05-2017, 10:02 AM
