1. DaniJean44's Avatar
    I have a Samsung S6 on AT&T and if I have my phone on the charger while I'm on a phone call, (only tried this while on the rapid charger if it makes a difference), when it reaches 100% and shows that little notification on the screen saying so, the phone call cuts out. It doesn't disconnect but I can't hear the other party anymore and they can't hear me. I have to disconnect and call them back, then as soon as I do, the audio cuts out again as soon as that little notification pops back up. No other notification causes this, email, text, etc., only the battery reaching 100%. My work requires that I be on the phone A LOT and so it behooves me to have my phone on the charger pretty much the whole time. I have tried Googling this but have had no luck in finding anyone else with this issue. I have gone through all my settings to see if I can turn off just that notification, but can't find that option anywhere. Would love some feedback or a solution to this.
    03-14-2017 01:22 PM
  2. Aquila's Avatar
    One suggestion might be to take the phone off the charger during a call and replace it following the call.
    03-14-2017 01:27 PM
  3. DaniJean44's Avatar
    And I do that occasionally, but I actually have phone calls that can last a few hours, and losing audio during an important call is not very professional. I'm just hoping that I'm not the lone wolf in this and that someone knows how I can turn off the notification or some other solution that will fix this.
    03-14-2017 02:00 PM
  4. lucianus_luciferus's Avatar
    open phone app, go to more, settings, call alerts, and disable notify during calls
    03-14-2017 02:35 PM
  5. DaniJean44's Avatar
    That was one of the first things I tried last week when it happened. Didn't work because it's a system notification instead of a device notification I guess.
    03-14-2017 02:45 PM
  1. My battery is draining ridiculously fast, is there a fix?
    Last Post: 03-17-2017, 08:55 AM
  2. I lost my phone S7 edge and had some pictures in private.
    Last Post: 03-14-2017, 01:15 PM
  3. Why does my phone looses GPS signal when it blocks?
    Last Post: 03-14-2017, 01:04 PM
  4. Incoming calls go right to voicemail
    Last Post: 03-14-2017, 10:59 AM
  5. Replies: 1
    Last Post: 03-14-2017, 10:57 AM
