1. AC Question's Avatar
    Hi, the power button has stopped working on my GS6. I think it's a software problem because I can do a power+volume down combo but power on it's own doesn't do anything. I've tried a factory reset though and that didn't seem to work either...
    Anyway I digress, I don't really need the power button except to quickly lock the screen, like if I want to put the phone in my pocket.
    Does anyone know of an app or gesture I can use to lock the screen without using the power key?
    Cheers!
    03-20-2017 04:03 PM
  2. SpookDroid's Avatar
    There are quite a few apps in the Play Store that can do that, but launchers like Nova can also set shortcuts/gestures to lock/turn-off the screen. The only 'downside' of turning it off like that is that it's always locked, so turning the screen back on will ask for your lockscreen password/pin/fingerprint no matter what the lock timer on your settings is.
    03-20-2017 04:56 PM
  1. Replies: 1
    Last Post: 03-31-2017, 11:26 AM
  2. Why j7 prime menu key light not working
    Last Post: 03-20-2017, 07:18 PM
  3. Replies: 0
    Last Post: 03-20-2017, 02:20 PM
  4. why is my screen darkened and locked on my galaxy s6 active
    Last Post: 03-20-2017, 10:59 AM
  5. Replies: 1
    Last Post: 03-20-2017, 10:04 AM
