    Not able to expand on the question re locating and changing the notification of a low battery percentage left .
    02-26-2018 12:33 PM
  2. Rukbat's Avatar
    Why would you want to? Running the battery down to 20% all the time is a good way to kill it quickly. 30% isn't too healthy. 40% should be your "recharge or turn off" point. Lithium batteries aren't used in phones because they can be deeply discharged, only because they're light for the amount of power they deliver. (And you don't want to carry a 5 pound lead-acid battery around with you.)
    02-27-2018 04:25 PM
  1. possible to update unicode?
    By Mrduder21 in forum Samsung Galaxy S8 & S8+
    Last Post: 10-02-2018, 11:22 PM
  2. My Samsung 8+ deletes my all music file by it self
    By Jack778 in forum Samsung Galaxy S8 & S8+
    Last Post: 09-11-2018, 01:20 AM
  3. Thinking about jumping to S9+ from LG V20
    By LuvMusic in forum Samsung Galaxy S9 & S9+
    Last Post: 03-05-2018, 09:47 PM
  4. Whats wrong my battery percentage is not moving
    Last Post: 02-26-2018, 04:17 PM
  5. Why is my wireless charger flashing blue
    Last Post: 02-26-2018, 03:44 PM
