1. AwakEVE's Avatar
    I have no idea how to fix this issue. My S6 "crashed" yesterday and its been stuck on the 'Powered by Android' screen. I tried draining the battery and to no avail. I've looked at a few options to restart my phone:
    DOWN+POWER - works but still stuck on same screen. When I charge the phone, it gives me the empty battery charging image and stuck on that screen.
    UP+POWER and UP+POWER+HOME - doesn't work at all. So I can't even enter into recovery mode to wipe cache partition.
    DOWN+POWER+HOME - works, though I honestly don't know how to use Odin. And would NOT like to factory reset my phone as I'd like to keep my files or at least retrieve it if my phone is complete broken.
    Any help would be greatly appreciated. Thanks!
    01-21-2019 06:51 PM
  2. Tim1954's Avatar
    If just holding down the power button doesn't turn phone off then maybe a trip to phone shop where they have Odin and should be able reboot the device. Times like these I curse the sealed battery system...
    You may have to hold the button for a minute or more!
    01-21-2019 07:40 PM
  3. B. Diddy's Avatar
    Welcome to Android Central! If the battery icon never shows that it's charging, then the battery has probably failed. As Tim1954 suggested, bring it to a repair shop and see if the battery needs to be replaced.
    01-21-2019 08:41 PM
  4. AwakEVE's Avatar
    I don't think its the battery, but more of a system fail. It does technically charge even though the image shows no charge. I've drained battery out, turned the phone on and doesn't work of course. Then charge for a couple minutes, and still gives me the screen Powered by Android or if I DOWN+POWER+HOME, it'll give me the Download mode. So it still holds charge.
    01-21-2019 11:47 PM
  5. B. Diddy's Avatar
    Well, it's worth a shot -- here's a guide on how to install firmware using Odin: http://forums.androidcentral.com/amb...interface.html
    01-22-2019 12:55 AM
  1. Is It Good to Keep Your WIFI Set to ON?
    By TechTimid in forum General Help and How To
    Last Post: 01-24-2019, 04:19 AM
  2. Replies: 8
    Last Post: 01-22-2019, 03:10 PM
  3. Can you use the USB c cable that came with the Pixel to charge the Note?
    By robinhelenehebert in forum Samsung Galaxy Note 9
    Last Post: 01-21-2019, 09:54 PM
  4. I just want the old power screening back
    Last Post: 01-21-2019, 08:43 PM
  5. Replies: 2
    Last Post: 01-21-2019, 08:37 PM
