1. IMattUltra1's Avatar
    I recently replaced my galaxy S6 battery for a new, genuine battery. However, the battery life is performing the same as before the replacement. AccuBattery predicts it at 1650mAh! There are no apps draining the battery and I have wiped the cache partition, calibrated the battery and done a few 0-100% charge cycles. Does anyone known what this issue could be caused by, as my battery is no different to the 3 year old previous one!
    It is very annoying and I want to be able to get my good battery life back 😢
    06-25-2019 03:17 PM
  2. mustang7757's Avatar
    I dont know how long you got the battery replaced but within a weeks time it should learn , if it's been longer then that, take it back where you got the battery done.
    IMattUltra1 likes this.
    06-25-2019 04:57 PM
  3. IMattUltra1's Avatar
    Thanks for the reply. I will see how it goes as I do more charge cycles. Also, I replaced my battery myself. The first time I replaced it, the battery wasn't genuine off ebay and that's why I thought it was that fake battery causing the issue. I ordered one of ReplaceBase (it was genuine) and put that in the phone and it seems to have the same issue. That's why I'm posting here about it as I don't know if its another hardware issue like the charging port I will need to replace. Just typing this my phone has gone from 100% to 92%!
    06-26-2019 02:03 AM
  1. Galaxy Note 5 volume down button unresponsive
    By JustAdrian in forum Samsung Galaxy Note 5
    Last Post: 06-26-2019, 02:29 AM
  2. YouTube and Chrome using combined 431.8% of battery?
    By eccentricenthusiast in forum Samsung Galaxy S10 & S10+
    Last Post: 06-25-2019, 10:19 PM
  3. Battery Charging Notification
    Last Post: 06-25-2019, 12:52 PM
  4. YouTube and Chrome using combined 431.8% of battery?
    By eccentricenthusiast in forum Android Apps
    Last Post: 06-25-2019, 12:40 PM
  5. Galaxy S8 Apps opening after disconnecting from Car
    By Greeny69 in forum Ask a Question
    Last Post: 06-25-2019, 02:32 AM
