Greetings all,
I am new here, and mostly a newb when it comes to Android. I am blind so I use my S7 active with text to speech and the voice assistant on. This may seem minor to most of you, but for someone like myself who uses it all day... the Stock voices are Timmy and seriously annoying.
When I first set up my S6 Edge, I received a prompt to download a file called:
SamsungTTS HD US English
The "TTS" in the name indicated to me that it was a voice file, so I told the prompt yes. After the file had completed downloading, the voice on my phone change to a very acceptable voice that was easy to listen to. It also offered accurate pronunciation of letters as I was typing.
That prompt never came up on this S7. I looked through the Play Store, the Amazon App area, and the Galaxy apps app on my phone.. With no luck. So I am now stuck with the stock voices, and it's threatening to take my sanity. Can anyone out there direct me to any enhance or high-quality voices for the Samsung or Google Text-to-Speech engine? I cannot even find the Ivona HQ app for those voices.
Thank you in advance for your assistance and may God bless!
