    I picked up a couple Samsung brand wireless chargers for the S7. They work well but won't couple through the rubber case I'm using. Any recommendations on a thin case back so it'll work for wireless charging?
    10-16-2018 07:42 PM
  2. B. Diddy's Avatar
    I moved this to the S7 Cases forum for more specific traffic.
    10-16-2018 08:59 PM
  3. FiOS Dan's Avatar
    I've had good luck with the i-Blason Halo Series. There's a trade-off with protection because it is slim but that's probably to be expected if you are seeking consistent wireless charging.
    Which protective case for wireless charging-i-blason-galaxy-s7-edge-clear-black-case-31.jpg
    10-22-2018 01:59 PM
  1. Spigen Neo Hybird vs. Incipio DualPro cases
    By Moondoggy in forum Google Pixel 2 & Pixel 2 XL
    Last Post: 10-22-2018, 01:29 PM
