01-17-2019 03:14 PM
738 ... 2223242526 ...
tools
  1. compddd's Avatar
    I got the Spigen Neo Hybrid for my Edge. Wife has one for her iPhone 6S and loves it.
    Rose4uKY likes this.
    03-29-2016 05:03 PM
  2. cardboard60's Avatar
    I was Turned onto the S7E UAG case on this forum. Got to say its not bulky but has rubber bumpers on it.
    Has a solid edge to protect you accidentally hitting the buttons on the phone.
    Great case.
    Thought I would post a Video on it.
    Rose4uKY and mustang8918 like this.
    03-30-2016 11:24 AM
  3. makaroni's Avatar
    I got the slim armor as well, and I do like it but I feel like it makes the phone super heavy compared to other cases I have tried. Do you agree?
    Now that you mentioned it, I just changed cases for a sec and it does make the phone a bit heavier than my basic thin Speck case. I don't know if I'd use the words "super heavy" but it does slightly add more weight. But... If you rate the amount of protection you get with this case along with the minimal bulk, I'd say it's amongst the best.
    03-30-2016 12:22 PM
  4. Rose4uKY's Avatar
    My Slim Armor has been shipped. I'll use it more at work for watching videos on breaks. When I go out on the weekends I'll use my Symmetry probably. I am using my flip cover now I switch back and forth.
    makaroni likes this.
    03-30-2016 12:35 PM
  5. cardboard60's Avatar
    I have the spec case.
    I can't feel where it's any bulkier or heavier. You better get the scales out that will measure grams.
    03-30-2016 12:52 PM
  6. felloffthetruck's Avatar
    Put on my Speck Zebra today and it's a fantastic case. Great grip, buttons, and it's nice & thin.
    I'll throw up some pictures tomorrow.
    03-30-2016 10:27 PM
  7. ilordvader's Avatar
    New ones
    Attached Thumbnails Cases for the S7 edge-1c20160331_075927.jpg   Cases for the S7 edge-2c20160331_075852.jpg
    makaroni and felloffthetruck like this.
    03-31-2016 12:19 AM
  8. felloffthetruck's Avatar
    Here's a couple of pictures of the Speck Zebra on a silver S7 edge.
    Cases for the S7 edge-sp01.jpgCases for the S7 edge-sp02.jpgCases for the S7 edge-sp03.jpgCases for the S7 edge-sp04.jpgCases for the S7 edge-sp05.jpg
    03-31-2016 10:48 AM
  9. popkurn611's Avatar
    Anyone have the Ringke Fusion case? Or the Ringke Fusion Air? IF so can you post pics and comments?
    04-01-2016 10:21 AM
  10. Bryant Laney's Avatar
    I got my Seidio Surface in black today I'll post pics later when I am home and have my tablet for pics.
    04-01-2016 04:28 PM
  11. Bryant Laney's Avatar
    Leykis and felloffthetruck like this.
    04-01-2016 07:10 PM
  12. cardboard60's Avatar
ID:	222860Click image for larger version.
ID:	222861Click image for larger version.
ID:	222862Click image for larger version.
ID:	222863Click image for larger version.
    My wife has that case in her S5 I've been wanting to sell.
    I thought it was a candy she'll or something.
    Sh3 got it at Best Buy.
    04-01-2016 09:29 PM
  13. makaroni's Avatar
    Some pics.Click image for larger version.
    Looks clean. I'm not a fan of those 2 piece cases though. For some reason they're a beeotch to get off of the phone for me. I tried one on my phone in Best buy and thought I was going to have to buy it because I couldn't get the thing off lol. I'm handicapped when it comes to the pressing down and sliding it off. Clean looking case none the less. Is that a kickstand? I'm a kickstand junky
    04-02-2016 04:16 PM
  14. Bryant Laney's Avatar
    I am also not a fan of two piece cases but they aren't making a dilex and with redesigned surface it's not bad it has a snug fit and I hardly notice that isn't the dilex and yes that's a kickstand they have the best kickstand on seidio.
    04-02-2016 05:12 PM
  15. wxman2003's Avatar
    Just got this case today. Amazon.com: Samsung Galaxy S7 edge Case Clear Protective Cover - Black: Cell Phones & Accessories
    Perfect fit. The bezel of the case matches exactly the color of the phone. Raised corners allow for you to set phone on it's face and does provide some drop protection. The back is clear and has grip. Depending on which you get, there is a slight tint to the clear back. I got the black for the black phone. Best part, is there is no rainbow effect that you get with some clear cases, and it's not a fingerprint magnet.
    04-03-2016 03:29 PM
  16. tsells's Avatar
    After trying a few cases, I decided to try without any case but felt that the phone was too slippery.
    So ended up with Slickwrap (back and sides) in brown leather (the phone certainly has more grip this way), and BodyGuardz Contour HD screen protector.
    04-03-2016 04:25 PM
  17. Keith Molloy's Avatar
    Has anybody here tried the Obliq slim meta case or the Obliq flex pro? Both look great . The slim meta costs 10 bucks more here and for that reason iam leaning toward the flex pro as its equally as nice but iam wondering how bulky it is along with how it feels in the hand?
    04-03-2016 05:56 PM
  18. makaroni's Avatar
    http://i606.photobucket.com/albums/t...pslzwlac98.jpg
    http://i606.photobucket.com/albums/t...psbrihyyyu.jpg
    http://i606.photobucket.com/albums/t...psorqcpois.jpg
    Is that adhesive or something? Looks good and the textured material I'm sure helps with grip.
    04-03-2016 06:08 PM
  19. tsells's Avatar
    It's an adhesive skin: https://forums.androidcentral.com/e?...token=p0wULCBl
    It was fairly easy to apply and seems to stick pretty well.
    04-03-2016 07:33 PM
  20. abv0377's Avatar
    Hello all, I'm new here and new to my s7 edge. Was using an HTC one x for last 4 years so you can imagine how stoked I am about this phone. I am looking for protection in a case. Protection, protection, protection. I had a ballistic case on my other phone for the lifetime and it worked great. What do you all recommend for best drop protection? I have read the otterbox commuter and uag are good.
    04-04-2016 12:19 PM
  21. cardboard60's Avatar
    Have you looked on this thread at the urban armor guard case?
    Very light. Very good case
    mustang8918 likes this.
    04-04-2016 01:00 PM
  22. abv0377's Avatar
    I sure did look at the uag case, would it offer better protection than otterbox commuter?
    04-04-2016 01:19 PM
  23. cardboard60's Avatar
    The otterbox is too thick for me. I've owned it. The otterbox also takes away from the phones screen.
    The S7 is waterproof. ?
    Why would you want a thick case like the otterbox ?
    If I didn't think I would drop the phone, I wouldn't even get a case. But it slides off things without a case that has some rubber or silicone.
    The UAG meets military specs.
    How strong do you need it.
    Gonna throw it at things.
    I posted Videos on the UAG case.
    It also has rubber edges. Its very slim.
    And has protections down the edge so you don't accidentally hit the buttons.
    Just offered a great selection.
    Carry mine everyday.
    Look at post 578
    04-04-2016 01:43 PM
  24. racingvike's Avatar
    I bought an Incipio at the same time I bought my Edge and didn't really like it from Day 1. Felt too flimsy and slick to the touch. Finally after 3 weeks of looking around online, I ordered the SUPCASE Unicorn Beetle for $18 on Amazon. I am very surprised at how well put together this case is and how with little added bulk it feels very sturdy. I do not use the snap on belt clip which also covers the screen as I don't wear my phone on my belt, but it clips on very secure as well. Great looking case and adds quite a bit of grip as well. The little added width on the edges also seems to have stopped the inadvertent screen touches as well. Little tricky to get apart the first time, but once figured out goes on and off fairly quickly. Great case.
    I've used Otterbox before on other phones, but feel this case offers more protection at half the price.
    04-04-2016 03:23 PM
  25. ctk4949's Avatar
    04-06-2016 02:53 PM
  1. Edge Features - Do you truly use them?
    By mc4nam in forum Samsung Galaxy S6 edge
    Last Post: 03-07-2016, 07:58 AM
  2. Can the camera shoot in 4K or what?
    By icellphones32 in forum Samsung Galaxy S7 edge
    Last Post: 02-23-2016, 08:27 PM
  3. Qwerty Remote App for Sony Blu Ray?
    Last Post: 02-23-2016, 01:24 PM
  4. Replies: 7
    Last Post: 02-22-2016, 03:54 PM
  5. Best video calling app for Android?
    By BeLO in forum Android Apps
    Last Post: 02-22-2016, 01:03 PM
