07-04-2017 05:18 PM
247 ... 34567 ...
tools
  1. Bryant Laney's Avatar
    Ugh why does it only do one at a time?
    04-01-2016 06:21 PM
  2. Bryant Laney's Avatar
    3
    04-01-2016 06:22 PM
  3. Bryant Laney's Avatar
    4
    04-01-2016 06:22 PM
  4. Bryant Laney's Avatar
    5
    04-01-2016 06:22 PM
  5. Bryant Laney's Avatar
    Last
    04-01-2016 06:22 PM
  6. felloffthetruck's Avatar
    Nice looking case. think I'll go and order one up with the clip. The surface case for the iPhone 6s plus the holster will fit the Apple leather case 100%.
    I'm hoping the Seidio Clip will work with cases like the Otterbox Symmetry.
    04-01-2016 08:42 PM
  7. Bryant Laney's Avatar
    They are my favorite case manufacturer been using them since my htc Evo 3d If I remember right. Good luck on the clip hope it fits with the Symmetry.
    04-01-2016 09:17 PM
  8. Rose4uKY's Avatar
    Sedio was always our favorite since the EVO's also. They used to let me review sometimes for a free case but here lately Otterbox had been out 1st so I switched to the commuter and now have the Symmetry. My husband had been using the defender which they don't make for the edge. So he's wanting to try Seidio again cause he wants the holster clip. I just got my Spigen slim armor with the kickstand so I won't be doing Seidio but I told my husband about the 15% off. This is my 1st Spigen case but it's hard to get the kickstand out.
    04-02-2016 02:07 PM
  9. ramonq619's Avatar
    I bought a spigen clear case and that case peeled my screen protector. Changed to a caseology case and it's perfect
    04-02-2016 02:47 PM
  10. Bryant Laney's Avatar
    I like otterbox but they are pricy. I've never tried spigen I usually stick with otterbox, seidio, oem or nillkin.
    04-02-2016 04:14 PM
  11. Rose4uKY's Avatar
    I know the speigen is kind of messing up my screen protector.
    04-02-2016 04:59 PM
  12. kappatau808's Avatar
    2 kinds of VRS design cases and both are peeling off a little bit of the screen protector on some edges. im using film skin protector. tried 2 kinds. both fit perfect. just issues with cases. i also tried skinomi full body skin protector, you can put them on the sides too. however i took the back and sides of cause i had a hard time putting the cases on and i thought the protector made it too tight. figured out the VRS cases i have are 2 piece,put on rubber case first then the plastic bumper. but all this peeling is getting annoying, i might just get another skinomi full body protector and just not use a case
    04-03-2016 11:07 PM
  13. jlczl's Avatar
    I quit using screen protectors after my Note 4 and haven't experienced any scratches so I decided to stop wasting money on them.
    My SG7E in a UAG Cobalt blue case fits pretty well in the Seidio clip for my Note 4 btw with just a very minimal width difference. It's in there nice and secure.
    04-05-2016 07:46 PM
  14. Loozpatienz's Avatar
    I just pre-ordered from Amazon the GPEL full coverage Gorrila Glass screen protector and the clear case that is compatible with it for $40 total. The screen protector will be available to ship on 4/8 and the case on 4/22. I like the minimalist look while protecting against scratches. May have to get a second, more protective case for extreme situations, once I find one compatible with the screen protector.
    04-05-2016 08:52 PM
  15. cmeinck's Avatar
    Wow, the GPEL looks pretty good. Let us know how it works for you. I installed a wet application - the IQ shield. For one, I don't miss doing this installations. I think I did a fairly good job, but it still takes away from the look of the device. When paired with the UAG case, it offers good protection. It's taking away from the beauty of the device. If this tempered glass looks good, I'm ordering.
    04-07-2016 07:15 AM
  16. Rose4uKY's Avatar
    My husband ordered the IQ one cause of the price it should be here today I think. We wanted the Gpel until we found out you had to use their case. I'm still waiting to hear from Zagg.
    04-07-2016 11:24 AM
  17. Captpt's Avatar
    My Spigen Curved Crystal and Zagg HD Dry protectors arrived at the same time...
    Not sure which I want to try 1st lol
    04-08-2016 01:51 PM
  18. felloffthetruck's Avatar
    Does the Spigen include 2 or only one?
    Please post the results.
    04-08-2016 02:12 PM
  19. felloffthetruck's Avatar
    Come on Cap, let's see those screen protectors installed.
    04-08-2016 09:25 PM
  20. ogio's Avatar
    i've tried the bodyguardz, zagg hd wet, and the spigen. the spigen is the best in my opinion. dont even notice there is a protector on.
    04-08-2016 10:25 PM
  21. lostsoul2's Avatar
    I just ordered the Gpel. hope you guys found a good one. so many have bad reviews out there.. looks simple to install. I wonder if it would help to use a hair dryer on it after install to help with the bonding and how long to wait till you put on a case. I think allot of people throw on a case too soon.
    04-08-2016 10:48 PM
  22. ogio's Avatar
    felloffthetruck likes this.
    04-08-2016 11:20 PM
  23. louzer's Avatar
    I'm using a Unicorn Beetle Pro case with a holster. I also have the Zagg HD screen protector. Because the top plastic piece fits on top of the screen and not from behind, it pays down over the edge of the protector instead of coming from underneath and peeling the protector when you secure the case.
    But after a few times having to remove the case to remove / reinstall my memory card, I noticed the sides of the protector starting to lift.
    I also put a Dbrand skin in the back of my phone (to prevent scratching from the inside of the back of the case). The instructions for the skin had me use a hair dryer to soften the edges and make them stick better.
    So I tried a hair dryer on the edge of the Zagg protector and gently pressed the edges down for a couple of minutes. Now the protector sits flush against the entire screen.
    I recommend trying this before getting frustrated and ripping off your film screen protector and buying something else.
    Posted via the Android Central App on the edge
    04-09-2016 11:55 AM
  24. Captpt's Avatar
    I went with the Spigen since I have a Spigen case it will used with.. I did the usual in the bathroom after a shower keeping dust to a minimum. Little trickier with the Edge curved glass but it went well, looks great and even after putting my Neo-Hybrid case back on the edges are not lifting(worried the edges may meet causing the edges to lift but everything is looking good. Not as nice as glass will be but looks good and the screen is protected..
    Good Edge cases and screen protectors??-photo.jpgGood Edge cases and screen protectors??-pho-copy.jpg
    purpleparrotuk likes this.
    04-09-2016 03:24 PM
  25. imex99's Avatar
    04-09-2016 08:57 PM
247 ... 34567 ...
  1. Replies: 5
    Last Post: 03-11-2016, 12:45 PM
  2. Lock screen clock change
    Last Post: 03-10-2016, 06:27 PM
  3. Camera on N and M
    By itguyjax8430 in forum Android 7.0 Nougat
    Last Post: 03-10-2016, 01:26 PM
  4. Good Edge cases and screen protector??
    By gnuser in forum Samsung Galaxy S7 edge
    Last Post: 03-10-2016, 11:53 AM
  5. Screen Rec/Mirroring and Internal Mic
    By Sean Leckie in forum Google Nexus 4
    Last Post: 03-10-2016, 11:26 AM
