07-04-2017 05:18 PM
247 ... 45678 ...
tools
  1. casiouser's Avatar
    I'm ordering the Samsung brand protective case from B&H. It keeps the look of the phone and isn't too bulky.
    04-10-2016 06:16 PM
  2. felloffthetruck's Avatar
    I went with the Spigen since I have a Spigen case it will used with.. I did the usual in the bathroom after a shower keeping dust to a minimum. Little trickier with the Edge curved glass but it went well, looks great and even after putting my Neo-Hybrid case back on the edges are not lifting(worried the edges may meet causing the edges to lift but everything is looking good. Not as nice as glass will be but looks good and the screen is protected..
    Attachment 224017Attachment 224018
    Do the sides of the Spigen peel up when using a case? They look mighty deep.
    04-10-2016 08:24 PM
  3. Captpt's Avatar
    So far no, the edges haven't budged and it looks like the Spigen Neo-Hybrid's rubber bumper edges protects the screen protector's edges so you can't accidentally hit the edges causing them to pull up or peel.
    04-11-2016 09:42 AM
  4. JHStewart1023's Avatar
    I went lifeproof this morning.... I couldn't stand not having a screen protector.... yeah it was more than I wanted to spend but I know it will work
    04-11-2016 09:55 AM
  5. Rose4uKY's Avatar
    I went with the Zagg HD and it's already messed up, My phone did fall out of my pocket once at work but cases are messing it up and the Symmetry does better but the Spigen Slim Armor is messing it up. I was thinking should i get the Spigen curved since I am using Spigen case but I switch around from my Symmetry and to my S flip cover. I am waiting for the Zagg glass curved so I can just pay the upgrade fee but I want another one on their now in the mean time since this is messed up. My husband did his liquid one last night forgot the name someone else bought one it was like $7.85 and he said he wished he had bought 2 cause this was just like a test but he did pretty good putting it on it's ok. I think I'll check into the Spigen since it's a curved one and comes with 2. So if it messes up I'll have an extra or my husband can have it.
    Let me know how you like the Spigen? I went to Amazon just now and the 1st so many reviews were bad. Thanks!
    My Spigen Curved Crystal and Zagg HD Dry protectors arrived at the same time...
    Not sure which I want to try 1st lol
    Attachment 223929
    04-11-2016 12:42 PM
  6. csleverette's Avatar
    Well I ordered the GPEL one and installed it today. I will try and get some pics later. No bubbles no dust. I use an Urban Armor Gear Cobalt case with mine and I do not currently see where the case is interfering with the GPEL protector. I also put on my Candy Shell Grip case and although its a tighter fit, I didn't notice any impairing of the protector. I will see how things are going at the end of the week.
    04-11-2016 01:50 PM
  7. LGalaxyGirl's Avatar
    I bought both the Spigen Curved Crystal and the Zagg Original Invisible Shield. They're in the garbage. The biggest problem was bubbling.
    I'm waiting for Tech Armor's ballistic glass protector. Had them with my S3 and S5. It saved my S5's screen once. Great investment. I just don't know when it's coming out.
    My case is a Spigen Ultra Hybrid with the case ring (got it free with the deal Spigen had in March.) It gives a good grip, something this slippery beast of a phone really needs.
    04-11-2016 02:03 PM
  8. Captpt's Avatar
    You had bubble issues with the Spigen curved crystal?? When installing or afterwards? I had some during installation but I kept pulling it back to the bubbles then relaying it pressing down and sliding my thumb against the screen until there were only a couple bubbles near the ends which were easily pushed out using the included plastic scraper.
    Patience and a dust free room is key.
    04-11-2016 04:32 PM
  9. csleverette's Avatar
    For those interested. After running the GPEL and the Candy Shell Grip for the afternoon I noticed through use that indeed this case was affecting the GPEL install. I removed it, re-seated the GPEL, and put my UAG back on. So no go with this protector and the GPEL.
    04-12-2016 07:34 AM
  10. LGalaxyGirl's Avatar
    When installing it. I used the scraper, and I even waited a couple of days to let the bubbles settle. Nothing. In the garbage!
    04-12-2016 11:07 AM
  11. kb31's Avatar
    I guess I'm going shopping for cases.
    I love the minimalist, slick feel of my naked S7E. However, this is, to quote Julia Roberts, a "slippery little sucker".
    It keeps sliding WAY too easily out of my pocket, and I'm lucky so far that it has not landed on a hard surface and cracked.
    I'm thinking about waiting for the Mophie battery case, but not sure how much longer I want to risk it breaking.
    You should get the Samsung battery case instead.
    04-12-2016 04:43 PM
  12. LordAndroid's Avatar
    How's it working 4 u?
    Its worked out well
    04-13-2016 12:50 AM
  13. oks10's Avatar
    I bought the Spigen Curved Crystal and am really happy with it. Good thing it came with 2 because I failed on the first attempt... It was a bit of work getting the edges to completely stay down but I just kept applying pressure to it until it was mostly gone. Left it caseless overnight and the following day and the remaining air gaps appear to have taken care of themselves, maybe from the heat being in my pocket all day. Put my otterbox symmetry back on this morning and so far no lifting. For 8 bucks off Amazon, I'm incredible happy with the Spigen protector, even if I had to trash one. No bubble issues on the main portion of the screen for me.
    04-13-2016 11:59 AM
  14. DEman19901's Avatar
    I beg to differ. The Mophie offers better protection. The Samsung version leaves the glass completely exposed.
    04-13-2016 12:29 PM
  15. marzfreerider's Avatar
    I got 2 UAG cases for mine. Had them for other phones prior to this and have always had a great experience. Fits great, lightweight and very minimal.
    04-13-2016 11:58 PM
  16. Mike-Mike's Avatar
    does anyone have the Samsung battery case?
    04-14-2016 08:42 AM
  17. RockyMin's Avatar
    I'm loving my Otterbox Symmetry case. About a week ago, my phone fell out of my pocket and fell about 2 ft to a hardwood floor. It landed face down and there wasn't a scratch or crack on it.
    04-14-2016 09:09 AM
  18. Rose4uKY's Avatar
    Do you have a screen protector on? I love my Symmetry too! Mine fell out of my pocket at work when I was leaning over and It was in my uniform shirt pocket and I usually put it in my pants pocket. But at the time i was using my Samsung S Flip Cover and I have a HD Zagg and I thought i messed up the phone in one corner and my husband said no it's the screen protector. I saw a couple messed up spots and was so upset. But when he said no it's your screen protector I was like so happy. My protector messes up in my Spigen Slim Armor a little. I am back to my Symmetry I switch around. I like the Spigen cause of the kickstand.
    04-14-2016 10:02 AM
  19. oks10's Avatar
    Same happened to me except it slid off of the bar of my kitchen (elbow height) and landed face first on the tile floor. Probably one of the most cringing sounds ever, hearing that smack the tile floor flat on it's face... No cracks or scratches so the case worked! lol
    Rose4uKY likes this.
    04-14-2016 11:24 AM
  20. RockyMin's Avatar
    No, I am one of those people that never use screen protectors on my devices. I just don't like them and really never needed them. My screens have always stayed in great condition without them.
    04-15-2016 04:36 AM
  21. jeetu4444's Avatar
    I am using the tempered glass that comes with gold color and it fits great...I have installed a transparent case silicone with gold plated rim..no lifting from the edges of the tempered glass will post pics soon
    Posted via my Awesome Lumia 950 , Beautiful S7 Edge Gold or Surface pro 4
    04-15-2016 10:10 PM
  22. Rose4uKY's Avatar
    What brand of tempered glass do you have?
    04-15-2016 11:20 PM
  23. popkurn611's Avatar
    Where did you order this case from? I can't find it on any US sites
    Never mind
    04-16-2016 11:07 AM
  24. popkurn611's Avatar
    04-16-2016 11:08 AM
  25. X1tymez's Avatar
    Where did you order this case from? It's not on any US sites
    Here's website that offered it. http://www.casefanatic.com/samsung/c...dge-galaxy-s7/
    04-16-2016 03:10 PM
247 ... 45678 ...
  1. Replies: 5
    Last Post: 03-11-2016, 12:45 PM
  2. Lock screen clock change
    Last Post: 03-10-2016, 06:27 PM
  3. Camera on N and M
    By itguyjax8430 in forum Android 7.0 Nougat
    Last Post: 03-10-2016, 01:26 PM
  4. Good Edge cases and screen protector??
    By gnuser in forum Samsung Galaxy S7 edge
    Last Post: 03-10-2016, 11:53 AM
  5. Screen Rec/Mirroring and Internal Mic
    By Sean Leckie in forum Google Nexus 4
    Last Post: 03-10-2016, 11:26 AM
