1. Wim Thielens's Avatar
    i have the led view cover for the s7 edge. When i close the screen, the leds (clock) dissapear within a few seconds. Is there a way to keep them on?
    I don't see any advantage on showing the time when i just closed the case?
    03-11-2016 06:48 AM
  2. Lobwedgephil's Avatar
    Sounds similar to the S View and Clear View cases, they all turn off and act the same so I assume its intentional from Samsung.
    03-11-2016 11:17 AM
  3. Ivonius1's Avatar
    yup thats it, you can put it back on by pushing the power button.
    My case only shows the time, sms, calls and charging.... no music, volume, whatssapp, mail or other notifications. What about yours??
    Ivo.
    03-12-2016 09:45 AM
  4. MrGalaxyNL's Avatar
    Mine shows the same things as yours. I really miss the email & whatsapp notifications and the option to keep the leds on. About the music I read somewhere that you should download the samsung music player for the leds to work
    03-12-2016 01:30 PM
  5. Wim Thielens's Avatar
    yep, i tested the music app en for a few seconds an equaliser appears... and then a blank cover. Shame... always on display would have been nice.
    03-14-2016 09:06 AM
  6. Ivonius1's Avatar
    Witch app do you use? Do you have a link?
    Mine doesn't work...
    03-15-2016 08:37 AM
  7. MrGalaxyNL's Avatar
    It's samsung music you can get it from the samsung galaxy store
    03-15-2016 11:37 AM
  8. Ivonius1's Avatar
    hmmmm it only shows the time here....
    03-16-2016 04:04 AM
  9. AndreasSW's Avatar
    I hope it`s a Bug that the led cover goes black that fast??? Oterwise i have to return it as it`s total useless ...
    Andreas Schnederle-Wagner
    03-18-2016 01:16 PM
  10. AndreasSW's Avatar
    excactly ... when cover is closed - the LEDs, which should show the time, go black within a few seconds ...
    I want “always on“ approach like the S7 Edge itself ...
    03-18-2016 02:09 PM
  11. ddsps's Avatar
    Im wondering if there will be any updates or if someone can develop their own app
    04-15-2016 09:56 PM
  1. New photo-realistic "Real LED Watchface"
    By marcotronic in forum Android Wear / Wear OS
    Last Post: 07-10-2016, 12:42 AM
  2. Replies: 1
    Last Post: 03-11-2016, 02:30 PM
  3. Annoying LED flash on incoming sms & mail
    By geeyesgee in forum LG G4
    Last Post: 03-10-2016, 09:16 PM
  4. Replies: 1
    Last Post: 03-10-2016, 04:23 PM
  5. Replies: 1
