06-18-2016 04:05 AM
34 12
tools
  1. LSWMW's Avatar
    Why is no one considering flip cases other than the hard shell clear ones? All the Edge cases I am seeing people talk about on the forum are the ones with nothing that covers the front, just edges and back. Am I headed in a direction that either won't fit my new S7 Edge or is less protective of the front? I already have a tempered class screen protector. I have no interest in keeping a phone in my pocket, it's either in a purse, in my hand, or on a desk.
    I've had a S3 for almost 4 years with a leatherette flip case with magnetic close, with no damage ever to my phone, even the few times I've dropped it. I like how it keeps the screen clean in my messy purse, gives me something stable to hold onto, allows me to prop the phone up horizontally.
    03-21-2016 03:21 PM
  2. teristark's Avatar
    I prefer the wallet cases for the extra protection in my purse and scrub pocket. I just got this one in the mail for temporary use until they come out with the rustic leather one I had for my s6.
    PU leather wallet for s7 edge
    I'm not particularly happy with this one but it will do temporarily. The plastic shell that holds the phone is very loose. If I drop it the phone will probably bounce out, even with the magnetic clasp. I ditched the wristlet and replaced it with the one I had on my old leather case. It is stretchy so I can wrap it around the case to keep it secure. It for dang sure will not pop open now. One of the pockets for the debit cards are very deep and would swallow up the card so I won't be using that slot. If you like a stylus (I don't) there is room between the phone and fold for one. The stitching looks good/even and it is a cute design. I want to like it more but the feel just doesn't measure up to my old one. This one is very light and thin feeling.
    I just looked up the old one and decided to check out the store and I'll be darn if they don't have it already! I had to stop and order it before I finished this post. LOL Vintage Leather Case for s7 Edge Worth every penny!
    They have one with the magnetic clasp also but I don't like the design.
    03-21-2016 09:06 PM
  3. LSWMW's Avatar
    Honestly I like the look of the one with the green leaf! That green is my favorite color. Someone else who reviewed that case said that it fit tightly, perhaps you got a dud? Anyway, how is the corner coverage ... is it higher than the Edge screen to give better protection?
    For the one that matches what you had before, are you saying that it feels sturdier or more protective?
    03-21-2016 10:55 PM
  4. Truman82's Avatar
    Some people have had scratches from using a flip cover. That's why I haven't bought one yet.
    03-22-2016 01:57 PM
  5. rdrive41071's Avatar
    Not from a leather case it won't. I have a VRS wallet case and like it because I can remove the phone whenever I please. I hate using a case to begin with, which is why I went this route. I can keep it protected out on the run, and still take it out to show off it's beauty + phone won't fit my car mount with the thinnest case on it, and I have a wireless fast charger that hates cases.
    Truman82 likes this.
    03-22-2016 02:21 PM
  6. teristark's Avatar
    It is a flimsy plastic that would easily stretch out. Hopefully you know what I mean. The corners are great and it would protect in a fall...provided the case doesn't fly open. The magnet in the leaf isn't very strong. That is why I am using the stretchy strap to secure it closed. I really do like the look. The green leaf is why I picked it. LOL I was hoping it would be more than a $10 case. I do like it and it will protect if you never have accidents. I just don't trust myself.
    The other case is sturdier and thicker leather which creates more padding should it fall flat. The plastic shell is thicker and a tight fit. I'm hoping the new one fits as tightly. The leather is the kind that has a lot of character. The more it gets scratched up the better it looks. It is worth the $40. (and I'm usually cheap lol)
    03-22-2016 07:28 PM
  7. teristark's Avatar
    I've never had a scratch. I use tempered glass and even that never got a scratch.
    03-22-2016 07:38 PM
  8. jbritt11's Avatar
    I just received my gold S-View Flip Cover (Gold S7 Edge) and it's really nice! I previously had one for my Note 3, this one seems to be made of a different material. I also have a Speigen Neo Hybrid for this phone but I felt a little uncomfortable not having any protection for my screen since I put my phone in my pocket pretty often.
    03-23-2016 07:43 PM
  9. ajb1965's Avatar
    Why is no one considering flip cases other than the hard shell clear ones? All the Edge cases I am seeing people talk about on the forum are the ones with nothing that covers the front, just edges and back. Imheaded in a direction that either won't fit my new S7 Edge or is less protective of the front? I already have a tempered class screen protector. I have no interest in keeping a phone in my pocket, it's either in a purse, in my hand, or on a desk..
    What screen protector are you using if I may ask? I'm going to go the same route with a cover case.
    03-24-2016 11:54 AM
  10. LSWMW's Avatar
    I am using the Puregear Extreme Impact Screen Protector that I bought at the T-Mobile store.
    03-25-2016 12:29 PM
  11. LSWMW's Avatar
    I am using the Puregear Extreme Impact Screen Protector that I bought at the T-Mobile store. And interestingly, I went back there after researching and deciding upon a tempered glass protector and T-Mobile told me that they had a tempered glass protector. Now that I am looking at the box, this is NOT tempered glass. I'll admit I was freaking out on day#1 carrying a phone with no case and no glass cover so I was desperate to get something.
    03-25-2016 12:30 PM
  12. LSWMW's Avatar
    Just got a Spigen® Neo Hybrid Crystal™ Cover Case to tide me over til I find a case with cover that I like the look of and protects well. The Spiegen feels really nice, but I want a permanent cover to keep all the little crumblies in my purse from getting on it. I wondered about the S-View Flip Cover, just like the feel of a natural material.
    03-25-2016 12:45 PM
  13. rdrive41071's Avatar
    Some of the people on this site must be totally clumsy-uncoordinated- and careless with the phones they get, using bulging cases that make the phone look like a box phone from 1995, screen protectors that take away from screen quality- so on and so on. Every phone I have had in the past 10 years, I have dropped my phone I think one time. If you're like me and just careful and have phone insurance just to be safe, you're golden. I really just don't get it. You buy a beautiful phone- the best looking phone on the market and you bulk it up to look nothing like it? It just doesn't make any sense to me.
    03-25-2016 02:51 PM
  14. ajb1965's Avatar
    Because even the most carefully handled device can have an accident, and Gorilla Glass 4 is prone to scratches. These, and a myriad of other possible scenarios are why. If you are fortunate enough to be a parent, I'm sure your children are the most beautiful sights to your eyes, but you don't send them outside naked do you lol?
    A cover case provides both protection and adds to the appearance IMHO.
    03-25-2016 03:39 PM
  15. rdrive41071's Avatar
    You are correct, it does add to the appearance. It adds bulk to the otherwise slim looking appearance. And where do you see GG4 is prone to scratches? Every review I have seen says nothing of the sort. I don't believe that. To each his own - agree to disagree. I know there are people out there who agree with what I'm saying.
    03-25-2016 03:46 PM
  16. jaj_ne's Avatar
    I'm using the Icarer leather slim case. It's real leather, could be better quality but it does look nice. It'll do till something better comes along.
    http://www.amazon.com/gp/aw/d/B01CVM...cUvbUpU5092914
    03-29-2016 02:03 PM
  17. ajb1965's Avatar
    I ended up with the VRS faux leather flip case. It's not bad, fits well and looks nice. It will do until I can get the Samsung wallet display case at a decent price.
    03-30-2016 03:30 PM
  18. STARGATE's Avatar
    I got this vrs design about 3 weeks ago, almost everyone likes it.
    Who Is Using a Leather Flip/Wallet Case for S7 Edge?-uploadfromtaptalk1460409732385.jpg
    Who Is Using a Leather Flip/Wallet Case for S7 Edge?-uploadfromtaptalk1460409750243.jpg
    Who Is Using a Leather Flip/Wallet Case for S7 Edge?-uploadfromtaptalk1460409761683.jpg
    Just last Friday I got this Spigen one, it's also very nice (but a bit bigger than the vrs) and when people see it they ask me what phone and case are those.
    This Spigen can bend so you can watch videos on your phone, the vrs doesn't.
    Who Is Using a Leather Flip/Wallet Case for S7 Edge?-uploadfromtaptalk1460409923042.jpg
    Who Is Using a Leather Flip/Wallet Case for S7 Edge?-uploadfromtaptalk1460409930972.jpg
    Who Is Using a Leather Flip/Wallet Case for S7 Edge?-uploadfromtaptalk1460409941791.jpg
    04-11-2016 04:25 PM
  19. ajb1965's Avatar
    Does the phone fit snug in the spigen? That was a big problem with my HTC dot view, the phone would fly out of it sometimes if I flipped it open with one hand. The VRS is a nice case, fits good. I really like mine.
    04-11-2016 10:27 PM
  20. STARGATE's Avatar
    Yes, fits perfectly fine.
    I can't decide which of those 2 I like the most.
    I've used the Spigen only one day and the VRS I've used it a total of 6 days so far.
    Well, there's one thing I hate about the VRS, most of the time the cover presses on the home button and when I open it the camera is on.
    I don't have that problem with the Spigen.
    04-12-2016 12:25 AM
  21. bigpapa2001's Avatar
    Are you having any trouble with that screen protector sticking on the sides I've already tried 3 at tmobile and the sides don't stick
    04-12-2016 01:16 AM
  22. bigpapa2001's Avatar
    Are you have any trouble with that screen protector sticking on the sides of the phone I've gone through 3 at tmobile Cuz they don't stick
    04-12-2016 01:18 AM
  23. LSWMW's Avatar
    I am having no problems on the sides at all. Right next to the volume buttons there is a small amount of debris that has gotten underneath the screen cover, but the way the case fits makes it that I don't actually touch this area anyway so it isn't lifting up that I can tell. The sales person at the store is the one who put it on for me, he had his technique.
    04-12-2016 09:14 AM
  24. LSWMW's Avatar
    This is the kind of case I had in the past with my S3. I just want to have a nice color though. Not black, brown, or red for me. I came from having a purple case which I absolutely loved.
    04-12-2016 09:17 AM
  25. djh_wolf's Avatar
    I don't really understand any of this. Maybe I'm getting old. All I see are a thousand different minute variations on a single case type i.e rubbery back cover with rubbery bits around the edges, leaving the main part of the phone (huge screen!) completely unprotected.
    Sorry, I guess that's not true so long as the phone is dropped onto an absolutely flat surface. Then the military grade rubbery bits will absorb the impact. Woo.
    But if I drop my phone face down on a standard bit of outside ground, with say, a loose pebble or gravel or whatever, my phone's bollocksed.
    What happened to a decent flip-style phone case covering the screen? And not those cheap-*** ones from eBay which clip the phones in place with a crappy plastic bezel that'll snap after a few months of being tossed about in a bag or pocket?
    Definitely don't understand opinions from people who have purchased several of these (arguably) similar cases and have preferences on which one they'll use for going to work, then a different one for popping to the shops, and another for going out for a meal.
    Am I just finally becoming old and stupid without understanding that it's happening? Why isn't there a case out there that'll actually cover my screen without being a cheap *** 2 quid POS from eBay China?
    Edit
    So basically, why can't I just buy a UAG case, with that kind of kick-*** protection, but with the addition of a front cover (made of the same rubbery style material) with say, a leather spine and a magnetic catch.
    Not that I'm picky = p
    -/edit
    Solution:
    One uag case + one flip case + rivets. Perfection. =)
    teristark, LSWMW and MeatLoafT like this.
    04-14-2016 01:48 AM
34 12
  1. Youtube app not showing in app drawer, Galaxy S7. Any help?
    By AC Question in forum Samsung Galaxy S7
    Last Post: 01-12-2017, 09:20 PM
  2. New S7 sd card issue, any help?
    Last Post: 04-20-2016, 03:31 PM
  3. Replies: 0
    Last Post: 03-21-2016, 03:06 PM
  4. where is my go live icon on my g6?
    Last Post: 03-21-2016, 02:10 PM
