1. AC Question's Avatar
    I need privacy for my phone Samsung gs7 edge. Do anybody know where or if Samsung will make a privacy screen for it?
    04-06-2016 09:41 PM
  2. B. Diddy's Avatar
    Moved to the S7 edge Accessories forum.
    04-07-2016 02:02 AM
  3. Rixxo's Avatar
    that'd be cool to see. I saw a case on ebay featuring a "privacy screen"
    04-07-2016 07:36 AM
  4. Kirsten Bravo's Avatar
    Hi! I wanted to ask you if you alreadt bought a privacy screen for your s7 edge? Cause i'm also looking for it in ages. Your reply would definitely be helpful!
    06-24-2016 09:09 PM
  1. Re: Galaxy S7 voice to text feature missing from keyboard ?
    By AC Question in forum Samsung Galaxy S7
    Last Post: 07-14-2018, 08:22 PM
  2. Replies: 10
    Last Post: 10-26-2016, 12:33 AM
  3. Is this Samsung brand portable battery charger any good?
    By Blues Fan in forum Samsung Galaxy S7
    Last Post: 04-08-2016, 06:11 AM
  4. Removing empty folder on home screen
    By Walter Turns in forum Samsung Galaxy Note Pro 12.2
    Last Post: 04-07-2016, 08:07 PM
  5. Can I change the LED light indicator colors on my Samsung S7?
    Last Post: 04-06-2016, 08:37 PM
