1. skhalid93's Avatar
    Hey guys, anyone know if theres a waterproof case out there for the s7 edge? I would go towards life proof but they don't make it for the edge. If anyone has some suggestions, please let me know, thanks!
    05-09-2016 01:30 PM
  2. Lance Redden's Avatar
    It's already IP68 rated! Why used a waterproof case lol
    05-09-2016 05:08 PM
  3. marzfreerider's Avatar
    It's water resistant not waterproof. If you look at other threads on here about some people having issues after use in water then you may see the need for a waterproof case.
    05-09-2016 06:09 PM
  4. LdotAdot13's Avatar
    Lifeproof has cases. Have you looked into them?
    Sent from Sir Cletus Sexy IV.
    (S7 Edge Titanium)
    05-09-2016 09:05 PM
  5. naturalguy's Avatar
    Really no need for a waterproof case with the IP68 plus I'd doubt you would find one because of the curved screen
    05-10-2016 06:36 AM
  6. thegame161's Avatar
    that seemsa odd to me when every review i have seen with swimming to dropping it in a lake it worked fine. I've left it in the shower and was fine.
    05-10-2016 03:49 PM
  7. chanchan05's Avatar
    Yes you do. If you plan on using it near a pool with more than 1m depth. Or if you plan to go with it boating. The phone can only stand clean water. Once you go pool with chlorine in it, or salty water with all sorts of solutes on it, the water resistance capability drops quite a bit.
    05-10-2016 08:23 PM
  8. Bag of Leaves's Avatar
    Are you looking for a full-time case or just something to use when you're at the beach? If the latter, there's probably a waterproof bag-type "case" that will fit this phone. I have one for my previous phone (S3), but haven't checked if my S7 Edge will fit in it or not. Some have the ability for you to use wired headphones with it (though of course your headphones will get ruined in the water if they're not waterproof). You can use the touchscreen through the plastic "case". They have a lanyard so you can keep the phone with you when you're swimming (no worry about theft of the phone while you're at the beach).
    05-11-2016 04:16 AM
  9. naturalguy's Avatar
    Well then you should get an s7 and a lifeproof case. Case manufacturers are having issues making cases for the curved screen
    05-11-2016 07:05 AM
  10. chanchan05's Avatar
    And that's the point of this guy's thread.
    05-11-2016 07:40 AM
  1. S6 edge plus camera buzzing sound
    By Rizwan Basir in forum Samsung Galaxy S6 edge+
    Last Post: 09-20-2016, 01:42 PM
  2. Replies: 0
    Last Post: 05-09-2016, 01:00 PM
  3. How do i get into my s7 if it has a difrent Google account?
    Last Post: 05-09-2016, 12:45 PM
  4. International S7
    By PokeandaSmancake in forum Samsung Galaxy S7
    Last Post: 05-09-2016, 11:43 AM
  5. How can i find my yahoo and gmail email contacts on my S7?
    Last Post: 05-09-2016, 11:09 AM
