1. dayloon's Avatar
    Hi all,
    Just a quick question. Does wireless charging still work with a case on? Such as the spigen neo hybrid for example.
    Cheers
    05-14-2016 05:03 PM
  2. marzfreerider's Avatar
    Can't say yes to that case as I don't have one. I do use a UAG clear and also a UAG black case with no issues charging with it on.
    Posted with my S7 edge via the Android Central App
    05-14-2016 07:05 PM
  3. ShinyTop's Avatar
    Hi all,
    Cheers
    Yes.
    05-14-2016 10:00 PM
  4. thegame161's Avatar
    Hi all,
    Cheers
    All spigen cases will
    05-21-2016 02:53 AM
  5. bigoldthor's Avatar
    I have three different types of Samsung wireless chargers. This includes the desktop wireless rapid charger that also doubles as a stand, the regular round black sapphire one, and the little square mini wireless travel charger. In addition, I have 12 cases at last count. I think they have all worked together. Sometimes you have to be specific about where you set the phone, especially with a thicker case. But honestly most of the time they're pretty forgiving. I'm actually quite impressed considering how awful it worked on the S6 Edge+.
    Can't speak to the non OEM chargers.
    05-24-2016 12:20 AM
  1. Replies: 3
    Last Post: 07-24-2016, 02:15 PM
  2. WiFi poor signal and slow
    By AC Question in forum Samsung Galaxy S7
    Last Post: 05-15-2016, 07:50 AM
  3. Replies: 7
    Last Post: 05-14-2016, 10:09 PM
  4. Replies: 2
    Last Post: 05-14-2016, 08:37 PM
  5. why is my phone not charging after the update
    Last Post: 05-14-2016, 03:24 PM
