1. danlnyc's Avatar
    Product in question: http://www.amazon.com/Protector-Aqua...cUvbUpU5183727
    I originally had the Armorsuit but I was not happy with it and had it returned. I was having issues with defects and these squiggly weird marks that wouldn't go away.
    I've been looking for a new S.P and came across this one.The reviews look good. Has anybody tried this one yet? I searched the forum to see if anybody has but with no results.
    05-18-2016 12:08 PM
  2. Bag of Leaves's Avatar
    I haven't, but I really like the protector I got from Best Skins Ever. It is wet install (you mix water with a tad of dish soap and spray it on the back of the protector before applying it to the phone) and the only bubbles I had after squeegeeing them out did resolve within 48 hours like the instructions said they would. I got the kind that works with cases, front only, glossy. I like the button and phone speaker cutouts on it better than the one in your link, too.
    05-18-2016 09:21 PM
  3. danlnyc's Avatar
    I pulled the trigger on this S.P and I will let you guys know how it is when it arrives next week.
    05-20-2016 05:20 PM
  4. swiftysnake's Avatar
    I'm using verizon branded one with a spigen tough armor case. no bubbles or halo effect
    05-21-2016 11:07 PM
  5. mundo472's Avatar
    This is a great question. Been using a Zagg HD which kept getting pushed up on the edges with vena and spigen clear cases and a vena vArmor. I called Zagg and they suggested the Original as it's thinner. It was no better and is less slick than the HD.
    So, has anyone found a case/screen protector (not glass) combo that works? I like the cases I've got, but will try others if I have to.
    05-27-2016 04:24 PM
  6. Bag of Leaves's Avatar
    Try the Best Skins Ever screen protector that is made for use with cases. I have two different cases (a protective one from Obliq and a pretty one that is clear rubber on the back with flowers and butterflies) and it works perfectly with both. It is wet install (you mix a tiny bit of dish soap like Dawn with water and use a spray bottle to spray it on the back of the protector) and was easy to put on. I have no problems with bubbles. I got the glossy one for clarity and it is very clear. The feel of it is very good for a protector (one of the reasons I hadn't used a protector since the '90s until now). The case-friendly version goes right to the edge of the screen, so it should work with any case. I followed the instructions to not use the phone for twelve hours after installation and then I didn't put a case on it for forty-eight hours after installation (the amount of time it takes for any little bubbles to work themselves out), which isn't in the instructions, but I figured would be a good thing to do for the edges, especially since I ended up using too much water/soap solution, so had a little trouble getting them to stay down immediately (didn't take a super long time, though).
    05-27-2016 09:44 PM
  7. 103Softail's Avatar
    Been using Samsung led case, spigen wallet case & PDair holster for s7 edge and all are fine with Zagg HD
    05-28-2016 03:04 AM
  1. Replies: 1
    Last Post: 09-12-2016, 09:21 AM
  2. How can I delete all personnal data from S4 with dead screen?
    By LARRYSHAN20 in forum Ask a Question
    Last Post: 05-19-2016, 06:01 PM
  3. How do I enable content to be shown on lock screen?
    By AC Question in forum Samsung Galaxy S6
    Last Post: 05-18-2016, 09:24 PM
  4. Replies: 1
    Last Post: 05-18-2016, 02:39 PM
  5. How can I fix some blurry screen shots?
    Last Post: 05-18-2016, 01:35 PM
