Verizon shell holster case. Guy in Zagg kiosk applied the protector for me and then made sure it wasn't coming up with the case on. That was a week ago. Still not lifting (had the Zagg guy check it), although there are some areas away from the top, bottom and side edges where there seems like there is a small gap between the protector and the screen. However, I attribute this to the fact that the protector only has adhesive on the black areas at the edges and not on the whole protector moreso than the case.
