1. IMBA666666's Avatar
    So i have just bought the Fast Wireless Charger Stand Type from Samsung and it seems that it charges slower compared to the Fast Wireless Charger Pad Type.anyone else noticing this?with Fast Wireless Charging turned ON.the Stand Type charges from 20% to 100% in 1 hour 58 mins.whereas the Pad Type charges from 20% to 100% in 1 hour 32 mins.i use the adaptor and cable which came with my S7 Edge...and actually this is my 2nd Stand Type charger i bought.sold the first because i thought it was faulty.
    And 1 more thing,anyone using the LED Flip Cover together with the Stand Type charger?seems that everytime i open and close the cover it turns off and starts to charge again.
    edward kim6 likes this.
    08-26-2016 12:41 PM
  2. TylerLV76's Avatar
    Noticed the same thing. Not sure why its slower but it definitely is.
    08-26-2016 11:55 PM
  3. everlightdark's Avatar
    Timing is pretty close but I guess it just depends on what you think will be the more efficient and cost worthy of a charger!
    08-28-2016 12:02 AM
  4. IMBA666666's Avatar
    Hmmm, i thought I was the only one experiencing it...
    08-30-2016 09:18 AM
  5. IMBA666666's Avatar
    It isnt close if you ask me lol.
    08-30-2016 09:18 AM
  6. soulsmilen's Avatar
    Does the bottom of the phone sit away from charger, at all, due to the leaning on the stand?
    08-30-2016 10:10 AM
  7. IMBA666666's Avatar
    It kinda sits on the arc...but the manual says that it has 2 pads in the charger...i have tried it in both positions and same results...wierd that no one else found out about the speed.
    08-30-2016 10:33 AM
  8. soulsmilen's Avatar
    Might just be that 22 minutes wasn't as noticeable for others, and/or they expected/accept a wee bit slower time with the phone not sitting as flush on the stand as it does the pad.
    Doesn't help you, I know...
    08-30-2016 11:25 AM
  9. IMBA666666's Avatar
    1 hour vs 1 hour and 20 minutes is a big difference for me.hahaha.i dont need speed but it affects normal wireless charging too...
    08-30-2016 01:24 PM
  1. Replies: 1
    Last Post: 11-06-2016, 02:16 AM
  2. Is the note 7 heavy on software like previous Samsung devices?
    By ee_nay in forum Samsung Galaxy Note 7
    Last Post: 09-02-2016, 06:41 PM
  3. Replies: 1
    Last Post: 08-26-2016, 12:58 PM
  4. Wireless Charging pad in GM vehicles
    By Makad in forum Samsung Galaxy Note 7
    Last Post: 08-26-2016, 12:52 PM
  5. Replies: 1
    Last Post: 08-26-2016, 11:31 AM
