1. BBIronMan's Avatar
    I'm looking for a snap-back case for the S7 Edge - just to help my fat fingers from always triggering screen functions. TETDED seems to be a popular choice but I've also seen a # of posts indicating they wear pretty poorly and quickly. Any other leather snap-back type options? The non-folder types. Thanks, Cheers.
    EDIT: I should've clarified not the numerous poly/pleather/glued leather options. Otherwise there are a ton of options.
    09-05-2016 12:09 PM
  2. B. Diddy's Avatar
    Moved to the S7 edge Cases forum.
    09-06-2016 06:28 PM
  3. CheungJeb's Avatar
    Try the Pierre Cardin or tscase lambskin
    11-11-2016 06:49 PM
  4. EMostafa's Avatar
    Leather is my option, although it looks a bit bulky, but I like the natural feeling. Hah...
    11-17-2016 02:18 AM
  5. Tre Lawrence's Avatar
    Nice...
    Are you able to charge wirelessly?
    11-25-2016 12:32 AM
  6. ticketbabe2's Avatar
    I sure can't in my Tech21..have to take it out of case.
    11-26-2016 09:21 PM
  7. Tre Lawrence's Avatar
    The only drawback with regards to done of these delightful leather cases. I love my Vaja, but don't use it as much because it's too thick for wireless charging.
    12-01-2016 02:35 AM
  1. Replies: 4
    Last Post: 02-27-2017, 05:28 PM
  2. Replies: 12
    Last Post: 09-08-2016, 04:03 AM
  3. Replies: 0
    Last Post: 09-05-2016, 11:54 AM
  4. Replies: 0
    Last Post: 09-05-2016, 11:09 AM
