Best scren protector compatible with UAG Case
jhnnyblze2000
401
23
18
Im using the bodyguardz one from the att store. Not sure of actual name but it cost $25. It's not glass but it is a really nice screen protector. Ive used a bunch of different cases with it on and haven't had any problems with it peeling up.
dsharp41a
Bestskinsever-case fit. Glossy. Believe only available from bestskinsever website. Cost $8.99. Works great with my UAG case. Very smooth surface for a non-tempered glass screen cover and the edges do not lift up as roughly 1mm between edge of skin to case. Be sure to allow up to 96 hours after applying for all bubbles and small imperfections to work themselves out. My skin ended up perfectly with no bubbles or any imperfections.
jokomad
