1. Bbarbie's Avatar
    Hello, i recently got s7 edge and moved away from note 7. In my note 7 s view case I always saw time ,etc when cover was closed. If a new notification came it also would show up in window. In the s7 edge case it's always blank. I only see notifications if I just closed the cover and within seconds it's off and back to black blank window.
    Is this how it should work by design or am I missing something? Thanks
    10-12-2016 01:36 PM
  2. suitebliss's Avatar
    Are you using a screen protector? I just had the Zagg installed on my S7 Edge and ordered the S View case and I'm hoping it doesn't pull up the Zagg protector
    10-12-2016 05:52 PM
  3. Bbarbie's Avatar
    Hi yes I am using a zagg on it and it has not lifted the corners at all. So far that is working fine . I just wish I knew what to expect with functionality on s view case because the note 7 one did a lot more than this one.
    10-12-2016 11:13 PM
  4. suitebliss's Avatar
    Well, I'll receive my case and Friday and I'll be able to help. Little more.
    Bbarbie likes this.
    10-12-2016 11:34 PM
  5. suitebliss's Avatar
    Try this link because he did mention some settings for the case on the phone
    10-12-2016 11:42 PM
  6. Bbarbie's Avatar
    Thank you
    10-13-2016 09:59 AM
  7. ToddK's Avatar
    Can no longer set a background image for the s-view flip cover... Since updating to Nougat.... ๐Ÿค”
    Still my favorite case for the s7e but I miss my custom background image...
    02-24-2017 05:23 PM
  8. ToddK's Avatar
    Finally found the "accessories" menu.... After looking for over an hour... I did a search in settings for "accessories". ...And presto.
    So many damn settings hidden all over the place... ๐Ÿ˜๐Ÿ˜‚
    02-27-2017 06:20 AM
  9. ToddK's Avatar
    FWIW... this was the cover background image I was missing so much....
    Frozen Cape Cod... From space. ๐Ÿคฃ (I live in the middle of this pic.)
    02-27-2017 06:24 AM
  10. dibz79's Avatar
    I've got a case which is just like the s-view but it's not Samsung one. How can i get to these settings as it's not showing on mine at all?
    04-26-2017 03:37 PM
  1. Maximize your Samsung Promos part 2
    By Radarnow in forum Samsung Galaxy Note 7
    Last Post: 10-14-2016, 10:19 PM
  2. Replies: 1
    Last Post: 10-12-2016, 01:40 PM
  3. How to recover data from my black screen samsung s6
    Last Post: 10-12-2016, 12:26 PM
  4. Samsung Galaxy tablet with 8" Screen and S-Pen
    Last Post: 10-12-2016, 10:49 AM
  5. my samsung will not update firmware please help
    Last Post: 10-12-2016, 10:05 AM
