1. French's Avatar
    And I don't mean music! I just want a case that has a built in kickstand but doesn't rock whenever it's flat and I press the home button. Obliq has a clear one but when I press the home button the whole phone rocks...
    https://www.amazon.com/Kickstand-Cry...cUvbUpU5492094
    I just ordered the Spigen but they don't have pink
    https://www.amazon.com/Spigen-Cushio...cUvbUpU5492094
    I had this for my beloved Note 7 I LOVED it...alas don't see it for the Edge.
    https://www.amazon.com/Galaxy-Note-C...cUvbUpU5492094
    10-14-2016 08:07 AM
  2. the tall guy's Avatar
    https://www.amazon.com/Kickstand-Cry...cUvbUpU5492361
    https://www.amazon.com/Spigen-Cushio...cUvbUpU5492361
    https://www.amazon.com/Galaxy-Note-C...cUvbUpU5492361
    Hi, I wrote a review on the Seido cases for the S7 - http://forums.androidcentral.com/sam...galaxy-s7.html
    I didn't notice any rocking when the kick stand was out - pretty decent case imo.
    I checked their site, but could only see a red one, maybe you might find more https://www.seidioonline.com/
    French likes this.
    10-14-2016 09:44 AM
  3. French's Avatar
    Thank you. I've used Seidio in the past and been happy... Alas no pink. Don't these case makers know some of us ladies don't mind being girly with some things. And really there are guys and young 'uns out there that like pink too.
    the tall guy likes this.
    10-14-2016 09:59 AM
  4. mededitor's Avatar
    I'm not using a solid pink case, but I am rocking a pink camo case with kick-stand (also comes with belt clip, which I don't use). Got it on Amazon, it's made by NakedShield. Fits well and still allows wireless charging. Rubber inner shell and polycarbonate outer shell.
    Attached Thumbnails Is it REALLY asking too much for a pink case w kickstand that DOESN'T ROCK??-2490.jpg
    French likes this.
    10-18-2016 05:43 PM
  5. French's Avatar
    Wow thanks. I like that.
    ETA: I can't find THAT particular one anywhere. I prefer a black rubber inner shell over the pink one I'm seeing on Amazon. They have a gazillion styles to choose from but the ones that have the black inner shell don't have any outer designs that I care for. Does that kickstand also work in portrait?
    OMG no sooner did I type this then I found the one you posted.
    https://www.amazon.com/S7-Edge-Scree...cUvbUpU5503485
    10-18-2016 06:26 PM
  6. French's Avatar
    So for now I ended up with this:
    https://www.amazon.com/gp/product/B0...cUvbUpU5506005
    and also bought this:
    I installed the kickstand at the bottom of the case under the fine print. It's not ALL the way at the bottom of the case but very close. I can lay the phone down on its back and push the home button and no more rocking! The kickstand does stick out a bit but so far it's not bothering me. I just wanted the phone to stop rocking whenever I touched it. So for now that's my fix. Oh and mededitor: I ended up ordering an "I love cupcakes" case from your suggestion above. For some goofy reason it made me smile so I figured why not. I wonder if the clip on back pieces are available as a stand-alone purchase. You could really change up the look of your phone easily with those and I would assume less expensive since they wouldn't need to include the rubber shell or the holster.
    10-19-2016 03:03 PM
  1. Replies: 2
    Last Post: 10-14-2016, 11:45 AM
  2. rare camera is not working. help
    Last Post: 10-14-2016, 09:47 AM
  3. Update for Always on Display
    By swatguy51 in forum Samsung Galaxy S7 edge
    Last Post: 10-14-2016, 09:32 AM
  4. Should you buy another Samsung product, It's called Karma
    By 1dtbrown in forum Samsung Galaxy Note 7
    Last Post: 10-14-2016, 07:59 AM
  5. is my Toshiba 46UL610U android
    Last Post: 10-14-2016, 05:46 AM
