01-11-2017 08:02 AM
28 12
tools
  1. Serkle K's Avatar
    I've had a Ringke Fusion smoke color case for my BlackBerry Passport and it held up well for daily use for almost 2 years. Towards the last few months, the softer edges of the case started to peel away from the harder back panel. I suspect it was from using it with a holster and taking it off from time to time to clean to case and device. I also noticed, even though it was a smoke color, it did start to tinge and look dirty or a tad yellow after all that time.
    For the money, it was a really great case and kept my device in great condition.
    What are some of the other top clear cases, especially for the S7 Edge?
    I'm looking for a case to use mostly at home or on the weekends. I'd like it to be able to hold up well after a long while, but also need it to be functional with my screen protectors. I'm currently using the Armor Suit "case friendly" screen protector and a Supcase Unicorn Beetle Pro case. It's great for when I'm at work and constantly on the move, but I'd also like a clear case that does a really great job at protecting the S7 Edge as well, for easier going days or when I get home or on the weekends.
    Please list your clear case and let me know what how it's been for you. Pros, cons, best and worst.
    Thanks!
    Air Planet likes this.
    10-23-2016 06:14 AM
  2. randun's Avatar
    Same here. I did purchase a clear case but it doesn't offer the protection I'm looking for. It seems that most of the more robust protective cases are colored. I think this takes away from the beauty of the phone.
    10-23-2016 12:31 PM
  3. amyf27's Avatar
    I have a Tech21 smoke clear case and like it. Mainly used when I'm riding hybrid bike and phone is in the handlebar mount. Also have an Otterbox Symmetry.
    randun and tadpoles like this.
    10-23-2016 05:19 PM
  4. Serkle K's Avatar
    I got impatient, and I couldn't wait anymore. I broke down and purchased a Speck clear case from my local AT&T store. Now I'm returning one of the 2 Supcase Unicorn Beetle Pro cases I got. I originally had 2 of them, one in Black/Black and one Blue/Black. Keeping the Blue/Black for when I'm going to work and the gym and such. Keeping the crystal clear for when I am hanging out at home for the weekend or taking an easy weekend.
    randun likes this.
    10-23-2016 10:54 PM
  5. randun's Avatar
    So, my pick is sorta ruled by how protective the case is white maintaining user variability.
    10-23-2016 11:01 PM
  6. randun's Avatar
    I always buy stuff from Amazon so looked there first.
    Couldn't find the Tech21 case. Didn't try website yet.
    Found Otterbox Symmetry but not Clear/Clear case. Their website had it though.
    10-24-2016 11:15 PM
  7. randun's Avatar
    Will look at Speck case again.
    10-24-2016 11:16 PM
  8. bialy's Avatar
    How this one Obliq naked clear with kickstand ?
    https://obliqproduct.com/collections...nt=20364839361
    randun likes this.
    10-25-2016 01:52 PM
  9. randun's Avatar
    I checked this out & based on specs, have already placed an order on Amazon! Will report back once I receive & use.
    10-25-2016 02:36 PM
  10. stealthredhead's Avatar
    I originally purchased the Speck Candy Shell clear case for my S7 Edge but I hated the way it kind of detracted from the elegance of the S7 Edge, it made it look kind of clunky. I wanted a more minimalistic case that was still protective enough so I tried the Insignia™ - Soft shell case from Best Buy and I am much happier with that. I did drop my phone the other night on a hard ceramic floor and it didn't have a scratch on it.
    10-25-2016 03:20 PM
  11. Serkle K's Avatar
    I kind of felt the opposite with the Speck because it's clear, in comparison to my Supcase Unicorn Beetle Pro. My biggest worry about this device, and any of the Edge devices is the edges and corners. I think between the 2 I now have, they seem to have the best balance between case friendly screen protectors and actually protection on the device. Although, I like the that the Supcase seems to have a more raised lip that I like, I think the Speck is nice to look at and use for now. I just hope it doesn't yellow.
    It does seem to be a little slippery in the hand, but it makes the device wider like the Supcase, which, IMO, makes it better to hold and grip. I felt the S7E and even my N7, when naked, felt too narrow and almost uncomfortable for me to hold and type on one handed.
    10-25-2016 04:05 PM
  12. stealthredhead's Avatar
    The soft shell case I have now does have a lip at the top and bottom and around the corners (and is thicker there) and then slopes down around the the sides of the phone. If I turn it upside down, the glass on the phone does not touch the surface because of the lip, which seems to have worked out well as I dropped it and the corner hit the floor first but nothing broke. I kind of struggled with the Candy Shell case in that it seemed hard to push the power button on the right, and also in my case, I didn't like how it made the phone wider. I have smaller hands so the thinner case feels better to me.
    I totally agree about the S7E and the N7 feeling uncomfortable when naked, they seem so delicate that I felt like a nervous wreck using the phone until I got a case! Oh, and the fingerprints.... ugh! The phones are so beautiful though....
    Serkle K likes this.
    10-25-2016 05:24 PM
  13. bialy's Avatar
    Curious for the Obliq naked clear
    1) if the kickstand is such that the Volume or Power button is up
    2) if generally sleek or bulky
    3) if comfortable to hold, Or soft or leather shell better
    4) if screen protector would be compatible
    5) if it would fit slide into a belt holster
    10-25-2016 08:01 PM
  14. randun's Avatar
    Like I said, I'll report out. I can use your items to check things out.
    dm3ready likes this.
    10-25-2016 08:04 PM
  15. Deke218's Avatar
    This is my weekend case.
    Spigen Ultra Hybrid Galaxy S7 Edge Case with Air Cushion Technology and Hybrid Drop Protection for Samsung Galaxy S7 Edge 2016 - Crystal Clear
    https://www.amazon.com/dp/B01A7IDKMO...cUvbUpU5526467
    randun likes this.
    10-26-2016 08:39 PM
  16. Serkle K's Avatar
    https://www.amazon.com/dp/B01A7IDKMO...cUvbUpU5527686
    How long have you had it, how has it held up? Any major drops with it? Anything you might not like about it? what do you like most about it?
    10-27-2016 10:24 AM
  17. Syounger64's Avatar
    I love the clear case with the silver lining made by caseology. Really shows off my silver s7e nicely.
    10-29-2016 11:09 AM
  18. amyf27's Avatar
    tadpoles and Serkle K like this.
    10-29-2016 01:41 PM
  19. randun's Avatar
    Bought this one & love it.
    10-30-2016 08:35 PM
  20. bialy's Avatar
    1) if the kickstand is such that the Volume or Power button is up (is kickstand reversible)?
    4) if screen protector would be compatible - which specific screen protector do you recommend with it?
    randun likes this.
    10-30-2016 09:50 PM
  21. randun's Avatar
    1. Volume button down. Not reversible that I can see
    2. Cross between sleek & bulky
    3. Not leather but comfortable to hold IMO
    4. I'm currently looking into compatible screen protectors
    5. Haven't tried sliding into holster but kickstand serves as nice clip-on for waistband
    10-30-2016 10:07 PM
  22. bialy's Avatar
    ^ the technical customer support obliq person said reversible.
    Look at the third photo in your link.
    What color edge did you get?
    10-31-2016 12:28 AM
  23. randun's Avatar
    Don't know if this was addressed to me or not?
    I'll have to double-check on reversibility.
    I got full clear for my gold casing.
    10-31-2016 12:48 AM
  24. zizowireless's Avatar
    Have you heard about military grade cases ???
    They are very rough and tough which are safe to use.
    10-31-2016 05:34 AM
  25. bialy's Avatar
    I'm curious about that 3rd photo in link and kickstand reversibility?
    How is the amount of front lip (~1.5mm) protecting the front screen - seems modest protection at gain of slim design?
    10-31-2016 11:38 AM
28 12
  1. ZeroLemon S7 7500mah Battery Case Review
    By ChristianYe in forum Samsung Galaxy S7 Cases & Accessories
    Last Post: 11-13-2016, 04:34 PM
  2. Pixel Cases
    By imartez in forum Google Pixel & Pixel XL
    Last Post: 10-24-2016, 05:18 PM
  3. Order pixel with clear case slow down shipping?
    By kng916 in forum Google Pixel & Pixel XL
    Last Post: 10-23-2016, 07:45 AM
  4. OEM Clear Clase
    By mhw100 in forum Google Pixel XL Accessories
    Last Post: 10-22-2016, 01:17 PM
  5. Best and Worst Car Mounts
    By bialy in forum Samsung Galaxy S7 edge Cases & Accessories
    Last Post: 10-22-2016, 11:52 AM
