1. atomarchio's Avatar
    Does anyone know of a shell/holster combo (with belt clip) for S7 edge which allows for use of both headphone and USB port with both pieces connected?
    I am looking for something thin.
    Please let me know. Thanks.
    12-23-2016 01:20 PM
  2. Rukbat's Avatar
    My Otterbox Defender does on my Note 3, and I suspect that it would on the S7 Edge. (It's not thin, though. Thin and protective in the same piece is almost impossible.)
    12-23-2016 01:28 PM
  3. atomarchio's Avatar
    my concern is less on the protective and more on the thin. all of the shell/holster combos with belt clip I've found cover the bottom ports.
    trying to find product that leaves those ports open. Any ideas?
    12-23-2016 02:20 PM
  1. Replies: 13
    Last Post: 07-14-2017, 02:09 PM
  2. Replies: 1
    Last Post: 12-25-2016, 09:27 AM
  3. Camera restrictions s7 edge
    Last Post: 12-24-2016, 12:22 AM
  4. Replies: 1
    Last Post: 12-23-2016, 05:43 PM
  5. Replies: 1
    Last Post: 12-23-2016, 01:50 PM
