Hi
So I have just bought an s7 edge (which is absolutely the best phone I have ever owned) and I am using an otterbox strada case. If you own this case you'll know what I mean when I describe the part that holds the phone as very stiff. It's not plastic, but I think it's very very solid rubber. Basically this means whenever I want to insert or remove the phone I have to apply quite a lot of pressure to it. My question is will this damage the phone at all? If anybody has experience of using a case like this for a long time has this affected your phone in any way??
Thanks,
Alstheman5
Thanks,
Alstheman5
