1. AC Question's Avatar
    Will a magnet ruin my Samsung s7 egde battery case
    03-27-2017 03:34 AM
  2. sdmf's Avatar
    Are you sure you mean a magnet or just a piece of metal...... I have a slim metal piece on mine for my magnetic car mount and all is good.
    billthem00se likes this.
    03-27-2017 10:51 PM
  3. billthem00se's Avatar
    It's this for something like the magnetic mount I keep seeing on Facebook ads? If so, the information says it's safe.
    03-28-2017 09:40 AM
  4. Miggy1218's Avatar
    Does this affect wireless charging?
    03-28-2017 02:38 PM
  5. rick0415's Avatar
    Yes the metal plate will prevent wireless charging.
    03-28-2017 08:28 PM
  6. ab304945's Avatar
    Will affect nfc and android/Samsung pay
    03-28-2017 08:54 PM
  7. sdmf's Avatar
    It does NOT affect wireless charging.mine still works. I have the scoche magic mount thing or whatever it's called.
    Miggy1218 likes this.
    03-28-2017 11:04 PM
  8. Miggy1218's Avatar
    Where is the plate located on your device?
    03-30-2017 12:28 PM
  9. pontiac005's Avatar
    I have one mounted right in the middle of the back of my case I use to mount on a magnetic mount. No problems.
    sdmf likes this.
    03-30-2017 09:23 PM
  10. damo's Avatar
    I fancy one of these as well to mount my phone to a car mount.
    Can anyone confirm if the NFC chip still works for android pay?
    Does the magnet affect the battery, GPS, or wireless charging?
    Thanks 👍
    04-12-2017 05:00 PM
  11. sdmf's Avatar
    Not sure about nfc, never used it but I can confirm no battery issues, or wireless charging issues using magnetic mount
    04-12-2017 11:54 PM
  1. Why I can't watch the videos on instagram?
    Last Post: 06-03-2017, 02:36 PM
  2. My LG G3 Keeps Saying "LG System Server Not Working"
    Last Post: 03-29-2017, 05:08 PM
  3. Where can I find ROM to upgrade to android 6.0 Marshmallow?
    By fincx in forum Samsung Galaxy S5 Rooting, ROMs & Hacks
    Last Post: 03-29-2017, 03:12 AM
  4. all my contacts does not load from iphone 7s plus
    Last Post: 03-27-2017, 05:36 PM
  5. Replies: 2
    Last Post: 03-27-2017, 05:12 AM
