1. AC Question's Avatar
    Obviously the point of the edge is to have access to the screens that go off the edges. However I just bought the symmetry and the case (as to be expected) gives me access to the screen as it should.... are all the cases like this? Or is there a better option for screen protection
    05-20-2017 12:48 PM
  2. B. Diddy's Avatar
    Moved to the S7 edge Cases forum.
    05-21-2017 02:34 AM
  3. pontiac005's Avatar
    Some are better than others. I like my unicorn beetle pro case. It is a bit higher on the sides but I have not noticed an effect on the edge. Also it is more raised on the top and bottom of the front to help protect the screen.
    DEman19901 likes this.
    05-24-2017 10:50 PM
  1. Replies: 2
    Last Post: 05-21-2017, 09:57 PM
  2. what is my Samsung password
    Last Post: 05-21-2017, 02:39 AM
  3. How do I connect Facebook to the internet?
    Last Post: 05-21-2017, 02:37 AM
  4. What is a text msg from unknown address that just says mms
    Last Post: 05-20-2017, 01:10 PM
