1. Aaron Staska's Avatar
    Just received new Galaxy s7 Edge. Wanting to protect such an expensive phone from any cracking or damage, yet still keeping as much of the slick design of the phone. I really the Spigen Neo Hybrid case, however I also want to protect the screen itself with a glass protector to help lower the chances of the screen cracking. Are there any viable options for glass screen protectors that work with this case?
    Any suggestions are most welcome!
    Thanks
    allenethanm likes this.
    07-29-2017 08:46 PM
  2. Trent9810's Avatar
    I've tried a bunch of glass screen protectors and none have lasted pass 2 weeks of use. They either pop off or get a ton of dirt buildup at the edges then pop off also all of they made my touchscreen all but unusable. I now use Ghost Armor and a spigen walet case.
    08-07-2017 10:32 AM
  1. Replies: 11
    Last Post: 08-21-2017, 06:55 AM
  2. SG s6 active. Can I do a screen print?Copy
    Last Post: 07-29-2017, 08:04 PM
  3. Why does my screen go black while charging
    Last Post: 07-29-2017, 08:00 PM
  4. Best smartwatch that has a heart rate monitor
    Last Post: 07-29-2017, 07:45 PM
  5. Replies: 1
    Last Post: 07-29-2017, 06:40 PM
