    I currently have the supcase unicorn beetle case on my s7 edge and I've tried 4 tempered glass screen protectors and the case cracked all 4. I'm wondering what the best case/screen protector combo I can get is? Do I want dual layer, a flip case, or something else? I'm mostly concerned about the screen above all else. The screen needs more protection than the edges or back. Any suggestions welcome!
    10-23-2017 06:24 PM
  2. ghstrdr951's Avatar
    I'm using the same case (Pro) with the GPEL glass screen protector and have had NO problems whatsoever.
    10-25-2017 10:02 AM
  3. pontiac005's Avatar
    I'm using the unicorn beetle pro case with Pleson screen protector. Really like that combo. Tight fit but works as long as you don't keep taking the case off.
    10-28-2017 10:18 PM
  4. comandoed's Avatar
    Could you give me the links for both the Pleson Screen Protector and the Unicorn Beetle Pro Case?
    Am coming up with a lot of similar results and not sure which is the right one.
    thanks
    03-31-2018 07:46 AM
  1. I have the black screen death- HELP!!
    Last Post: 10-24-2017, 03:46 PM
  2. Does enabling USB Debugging on a samsung note 10.1 stop the tablet from charging?
    Last Post: 10-23-2017, 06:26 PM
  3. Replies: 1
    Last Post: 10-23-2017, 06:24 PM
  4. Replies: 1
    Last Post: 10-23-2017, 06:15 PM
  5. S7 Active can't lock onto GPS location
    Last Post: 10-23-2017, 06:01 PM
