1. ironass's Avatar
    The first custom ROM for the Galaxy S7 Edge has been released by developer mwilky over on the xda developers forum...
    Renovate Edge 1.0
    It is TouchWiz based.
    "Renovate EDGE 1.0 (4th April)
    Added Renovate Home - toggle different ROM options
    Enable/Disable 180 degree rotation
    Hide/Show certain notification/icons
    Enable/Disable Quick Quicksetting (pulldown on right side of statusbar to open quicksettings)
    Enable/Disable new SMS messages turning the screen on
    Various other tools
    Disabled loud volume warning
    Added DPI scaling options to Settings
    Added button light timeout to Settings
    Added AROMA option to enabled fingerprint unlock after a reboot
    Added TCE csc as AROMA option
    Fixed/Improved app removals
    Updated apps
    Enabled Secret Mode in browser
    Hidden software update from Settings
    Added Call/SMS block to Settings
    Added AROMA theme
    Renovate EDGE beta 3 (29th March)
    Fixed VR
    Fixed loads of possible errors due to missing libGLESv3.so
    All apps now support the multi window view
    CSC cleanups
    Ramdisk cleanups
    Updater SuperSU
    Renovate EDGE beta 2 (26th March)
    Rebased on G935FXXU1APC8
    Added AROMA installer
    Fixed all installer issues from beta 1
    Hopefully fixed SD Card, (please let me know)
    Added 5 way reboot menu
    Removed more bloat
    Enabled Settings/Dev Options by default
    Enabled adb by default
    Removed sd card notification
    Beta 1 - 17.03.2016:
    Initial release
    Deodexed whole system
    Standard Installer (AROMA will be in beta 2)
    Rooted with SuperSU (systemless)
    Added busybox
    Added init.d support
    System mounted RW
    Insecure boot.img
    Hopefully fixed RW permission to external SD
    File cleanups on each boot
    Enabled multi-languages
    Added a load of extra CSC features[/I]"
    This is for rooted users and is based on the unbranded U.K. release for the G935F model. Currently it is compatible with all Global G935F models as well as the G935FD, Duos, model, (on a single sim basis). Untested, as yet, on the Canadian, G935W8, model but should work. See the developers thread for more up-to-date information.
    This is for experienced and competent users. Please read the developement thread, carefully and thoroughly before proceeding.
    WARNING: DO NOT attempt to flash this on the S7 model or Qualcomm SnapDragon models.
    ironass motto... "Flash in haste... repent at leisure!"
    srkmagnus and Dawood Khan2 like this.
    03-24-2016 06:57 AM
  2. srkmagnus's Avatar
    Awesome! Are you running it? Also, is this only for the G935F model? I'm going to edit the title to suggest that it is so that users with non G935F devices don't go an install it.
    03-24-2016 07:19 AM
  3. ironass's Avatar
    Hi srkmagnus!
    Not running it personally. It is, as I stated in post #1, based on the Global G935F firmware but, as we are beginning to see in other posts and threads on the web, there is a crossover in kernels, firmwares, ROMs, mods, etc; to the G935FD, Duos, model and the Canadian, G935W8, models. However, as this ROM is so new, no one has tested this yet on those models which is why I did not restrict it to a particular model in the thread.
    Edit. Tested and found working on the G935FD model, here, on a single sim basis.
    I have amended post #1 to clarify the situation with the models concerned and with your permission, have re-edited the title. Hope you agree.
    srkmagnus likes this.
    03-24-2016 07:44 AM
  4. srkmagnus's Avatar
    Hi srkmagnus!
    Looks good to me - Thanks for the quick update and clarification. Hopefully this is a good sign of things to come for those who wish to install ROMs onto their S7's.
    ironass likes this.
    03-25-2016 10:31 AM
  5. Dawood Khan2's Avatar
    How i download this ROM...
    Plz tell me anyone
    03-27-2016 06:32 PM
  6. ironass's Avatar
    Plz tell me anyone
    Hello and welcome to Android Central Dawood Khan2!
    Just click on the link in post #1, above and it will take you to the developers website and download link.
    03-27-2016 07:14 PM
  7. ironass's Avatar
    RENOVATE EDGE beta 2, now up. Amended link in post #1 accordingly.
    03-27-2016 07:28 PM
  8. ironass's Avatar
    RENOVATE EDGE beta 3, now up. Amended link in post #1 accordingly.
    04-01-2016 09:31 AM
  9. ironass's Avatar
    The Renovate ROM is now out of beta and on release 1.0. Post #1 amended with latest updates.
    04-06-2016 05:21 AM
  10. sujan kharel's Avatar
    hi there how do i change dpi of my s7edge i cant find dpi option in setting. please help me
    04-06-2016 09:59 PM
  11. ironass's Avatar
    Hello and welcome to Android Central sujan kharel!
    Are you rooted and using the Renovate custom ROM in post #1?
    04-07-2016 05:20 AM
  1. Any problems with accidentally touching the edge?
    By robcassman in forum Samsung Galaxy S7 edge
    Last Post: 09-19-2017, 09:38 PM
  2. S6 Edge G925i stuck in bootloop
    Last Post: 05-05-2016, 12:01 PM
  3. Registering S7 edge online, why is it so difficult?
    By AC Question in forum Samsung Galaxy S7 edge
    Last Post: 04-27-2016, 08:10 PM
  4. Galaxy S7 Edge screen issue, can I get some help?
    By D-M-H in forum Samsung Galaxy S7 edge
    Last Post: 03-26-2016, 07:07 AM
  5. Why does the gallery keep stopping on my Galaxy S7 Edge?
    Last Post: 03-24-2016, 06:53 AM
