1. boostermbkking's Avatar
    LATEST FIRMWARE NOBRAND
    ANDROID 6.0.1
    SECURITY PATCH MAY 2016
    RELEASED 03-05-2016
    DEODEX
    ZIPALIGNED
    ROOTED 2.71
    BUSYBOX
    ADD SUPPORT TO S7 FLAT VARIANTS
    DISABLE SIGNATURE CHECK
    YOU CAN INSTALL OLD APP OVER NEW
    TRAFFIC METER IN STATUS BAR
    OPEN ALL TOGGLE ON RIGHT SWIPE IN STATUSBAR
    DEFAULT WINDOWS ANIM. x0.5
    VIRTUAL LOCK BUTTON SET TO LEFT CORNER STATUSBAR
    ENABLE OUTDOORMODE IN SCREEN SETTING
    ROUNDED NOTIFICATIONS IN NOTIFICATIONS PANEL
    REMOVED GREY BAR WHEN ENERGY SAVING WHAS ACTIVED
    REMOVED WARNING SAFE VOLUME
    ADD SBROWSER SECRET MODE
    FIX PERMISSION FOR EXT SDCARD
    SQLite3 OPTIMIZED
    RAM OPTIMIZED
    ZIPALIGN AT BOOT
    KERNEL INSECURE MODE
    FULLY SUPPORT FOR INIT.D SCRIPT
    3 MINIT BATTERY MOD
    POTATO CLOCK
    AVANCED REBOOT MENU
    DPI SCALING IN SETTING/DISPLAY
    TOUCHKEY LIGHT DURATION IN SETTING
    SMART MANAGER DUAL LAYER
    ADD SAVE/RESTORE SMS IN MESSAGE APP
    ADD DATA USAGE IN NOTIFICATION PANEL NEAR AUTO CHECK
    GEAR VR FULLY WORK
    ADD SAMSUNG MUSIC PLAYER
    ADD ULTRA DATA POWER SAVING IN SMART MANAGER
    REMOVED EMERGENCY BUTTON IN POWER MENU
    MULTIWINDOWS VERTICAL SCROLLABLE
    ROUNDED RECENT PANEL VIEW
    ADD QUICK LAUNCHER IN RECENT APP
    6 TOGGLE IN A ROW
    RAM BAR IN RECENT
    KNOX REMOVED
    MICROSOFT APPS REMOVED
    FACEBOOK, INSTAGRAM WHATSAPP REMOVED
    GOOGLE MUSIC REMOVED
    DUAL SPEAKER V16
    ALL APPS MULTIWINDOWS
    REMOVED SD NOTIFICATION AT BOOT
    FASTER FIX GPS
    MULTI FONT
    YAHOO PANEL EDGE
    MORE SOUND NOTIFICATIONS
    DIRECTORY FOR ZIP MOD in /sdcard/KING ROM S7 EDGE
    XPOSED READY TO INSTALL (/sdcard/KING ROM S7 EDGE)
    DISABLE ANTIMALWARE
    ADD 100 CONTACT QUICK CALL
    TOGGLE SOUND CAMERA IN CAMERA APP
    CAMERA WORK DURING CALL
    CAMERA DONT STOP MUSIC
    EXIT BUTTON FROM SAMSUNG BROWSER
    NATIVE CALL RECORDING
    CALL QUALITY IN HD
    ADD CALL BUTTON IN CALL LOG
    ENABLED VoLTE FOR SPECIFIC CARRIER
    MULTIUSER
    BEST QUALITY OF STREAMING
    KING BOOTANIMATION AT 60 FPS
    ENABLED SEARCH DIRECTORY IN ARCHIVE APP
    DISABLE CONVERSION SMS TO MMS
    ADD MEGA ADSBLOCK
    INCREASE BATTERY LIFE
    INCREASE PERFORMANCES
    ALLOW MOCK LOCATION
    ADB FULLY WORKING
    OTA UPDATER
    KING_ROM_S7_EDGE
    @Chainfire - For SuperSU
    @SuperR. - For Kitchen
    @svadev - For DEODEX tool
    @zubi182 - For Dual Speaker mod
    @Tkkg1994 - For adb fix, updater-script and efsbackup
    @Ticklefish - For Tickle My Android
    @raziel23x - For APK Multi-Tool
    @metaspook - For Viper4Android
    @Modaco - For ota updater
    @daxgirl - For Rom control
    @Enriquezdelaplaya - For beta test
    @proofer - For beta test
    In /sdcard/KING ROM S7 EDGE we are some mod to flash in recovery for install or remove XPOSED, DUAL SPEAKER, SuperSU...
    PRE-REQUISITE:
    Recovery TWRP
    Encription Disabler
    Root
    INSTALLATION:
    1. Download Rom
    2. Reboot in recovery
    4. Click on "advanced wipe" e select "dalvik cache", "cache", "data" and "system"
    5. click on "install" e select the ROM
    6. First boot during about 8 / 15 minuti, Relax...
    05-27-2016 04:35 AM
  2. boostermbkking's Avatar
    reserved
    05-27-2016 12:38 PM
  3. boostermbkking's Avatar
    From now, all the mod, bootloader, modem and much more inside my Rom, will added to my app, please download it for manage the Rom, also you can request personalizations from it
    05-27-2016 12:39 PM
  4. boostermbkking's Avatar
    reserved3
    05-27-2016 12:39 PM
  5. boostermbkking's Avatar
    v8 online
    06-14-2016 08:19 AM
  6. boostermbkking's Avatar
    V9 ONLINE
    07-14-2016 03:47 AM
  7. boostermbkking's Avatar
    v10 online
    07-27-2016 01:09 PM
  8. Zammo76's Avatar
    Does this mod have Wifi Calling? I have an SM-G935F S7 and have no option for wifi calling, despite my carrier (vodafone) having enabled it. Thanks.
    07-28-2016 02:34 PM
  9. boostermbkking's Avatar
    depend of CSC, choose the correct csc and all tweaks are enabled
    08-13-2016 04:28 PM
  10. boostermbkking's Avatar
    v11 online
    08-26-2016 03:40 AM
  11. boostermbkking's Avatar
    KING ROM S7 EDGE V12 ONLINE
    YOU CAN FIND IT IN PRERELEASE IN MY APP:
    HERE THE CHANGELOG:
    09-13-2016 11:29 AM
  12. boostermbkking's Avatar
    v13 online
    09-29-2016 03:50 AM
  13. boostermbkking's Avatar
    V14 online
    10-25-2016 11:21 AM
  1. Where is theStock ROM
    Last Post: 10-31-2016, 09:34 AM
  2. Is it possible to flash ROM using windows command?
    By fullscore21 in forum Ask a Question
    Last Post: 10-24-2016, 07:26 PM
  3. Replies: 1
    Last Post: 10-24-2016, 05:28 PM
  4. Replies: 1
    Last Post: 10-24-2016, 02:06 PM
  5. s5 active fails to flash stock ROM
    By nissan11 in forum Samsung Galaxy S5 Active
    Last Post: 10-23-2016, 06:22 PM
