1. benjaminllim's Avatar
    I installed stock 6.0.1 ROM on my S7 Edge and I checked SamMobile and there was a new firmware for my S7 Edge. But when I checked for updates it says "software is up to date."
    It ahs been out since December and I still haven't got it. I know 7.0 update is coming out in a few days and I'm unsure whether I'll get an OTA update for that as well.
    When downloading firmware I downloaded the AP and CSC files so I could change my CSC from EVR to BTU. After that I cleared cache and restarted.
    I don't think I've done anything wrong so I should be receiving updates
    Build number:
    G935FXXU1BPL2 (this came out earlier in the same month)
    Latest one I should've got: https://www.sammobile.com/firmwares/...5FBTU1BPK3_BTU
    01-13-2017 01:57 PM
  2. Tim1954's Avatar
    Ah, once you mess with sofware, you are on no man's land, you may not be able to get any updates at all...
    pontiac005 likes this.
    01-14-2017 06:57 PM
  1. vivo y51l radio off call not connect some answer me
    Last Post: 07-15-2017, 05:54 AM
  2. Google OnHub and Google WiFi not reporting speeds
    By Legobricke in forum Google Wifi
    Last Post: 01-13-2017, 12:39 PM
  3. Calendar event notification not working on Motorola turbo
    Last Post: 01-13-2017, 12:02 PM
  4. App on unlocking bootloader is not working, help
    By emgi2 in forum ASUS ZenFone 2
    Last Post: 01-13-2017, 11:47 AM
