1. AC Question's Avatar
    I wanted Nougat early rather than wait on AT&T. After flashing a modified AP file through Odin, I changed my mind. Ever since that happened, the phone is slow and inundated with notifications concerning security issues. I tried to restore to factory settings and flashing back to stock firmware...no luck in resolving the issues.
    I think I haven't been able to restore the phone to stock because of something related to either my baseband version ending with APK1 or something to do with the bootloader being 'rev 04.' I can't seem to locate firmware files that are compatible with my phone's current software.
    I am not really what to search for exactly and I haven't had any luck being able to determine where to locate compatible BL/AP/CSC/CL files. Please help!
    I have listed information about my phone and software below, please let me know if there is any other information needed to help me with my issue.
    MODEL #: SAMSUNG-SM-G935A
    ANDROID VERSION: 6.0.1
    SECURITY PATCH LVL: Nov. 1, 2016
    BASEBAND VERSION: G935AUCS4APK1
    Kernel Version: 3.18.20-7856276-ENG
    dpi@SWHD7309 #1
    Fri Apr 22 16:24:20 KST 2016
    Build Number: MMB29M.G935AUCS4APK1
    Security Enhancements: Enforcing
    SEPF_SECMOBILE 6.0.1_0010
    Fri Apr 22 16:29:47 2016
    Security Soft. Version: MDF v2.0 Release 7
    VPN 1.4 release 6.1
    ASKS v1.2_161011
    KNOX 2.6
    Standard SDK 5.6.0
    Premium SDK 2.6.0
    Customization SDK 2.6.0
    01-31-2017 05:44 PM
  2. belodion's Avatar
    (Moved to Samsung Galaxy S7 Edge Rooting, ROMs & Hacks forum.)
    02-01-2017 06:03 AM
  3. Jamie Privett's Avatar
    dpi@SWHD7309 #1
    VPN 1.4 release 6.1
    ASKS v1.2_161011
    KNOX 2.6
    Standard SDK 5.6.0
    Premium SDK 2.6.0
    I am looking for Stock Firmware also. Did you happen to find a resource yet?
    Thanks,
    Jamie
    02-09-2017 10:12 AM
  4. freeop's Avatar
    02-15-2017 11:35 AM
  5. alczaty's Avatar
    try via recovery in smartswitch app to download orginal stock firmware
    03-07-2017 10:33 AM
  1. unlock sprint galxy s7 edge
    Last Post: 02-01-2017, 03:03 AM
  2. Replies: 3
    Last Post: 02-01-2017, 02:50 AM
  3. My S5 wont connect to kies or smart switch
    Last Post: 01-31-2017, 05:16 PM
  4. How do I stop my sdcard from turning from FAT32 to RAW?
    Last Post: 01-31-2017, 04:50 PM
  5. Replies: 0
    Last Post: 01-31-2017, 04:33 PM
