1. evyatar ma's Avatar
    I updated to 7.0 nougat and since the update i cant change/download them
    when i try to always
    pop up a message
    "unable to download themes in show button shapes"
    did anyone knows a sloution ?
    03-08-2017 07:06 AM
  2. pkcable's Avatar
    Found a video on YouTube that shows a fix for this issue....
    03-08-2017 08:02 AM
  3. evyatar ma's Avatar
    thank you it work
    pkcable likes this.
    03-08-2017 09:39 AM
  4. pkcable's Avatar
    Glad you got it working! I edited your title to make the thread read more as a question that could be answered s it's more helpful to the next person with the same problem.
    03-08-2017 09:57 AM
  5. CHYNAKING 2010's Avatar
    I disabled easy mode first,
    Then accessibility and show buttons was highlighted and i turned it off.
    Turned easy mode back on.
    For Theme problems after update i changed the size of my fonts and screen zoom.
    Hope this helps just need to sort out my sd card corruption???
    12-15-2017 07:27 PM
  1. HATE the new update, how do I uninstall it?
    By Naamaco in forum Samsung Galaxy S7
    Last Post: 03-08-2017, 10:08 AM
  2. Replies: 1
    Last Post: 03-08-2017, 09:58 AM
  3. Turbo 2 and Nougat - why (and how) to do factory reset
    Last Post: 03-08-2017, 09:55 AM
  4. how do you put music on the samsung 6
    Last Post: 03-08-2017, 09:47 AM
  5. Replies: 0
    Last Post: 03-08-2017, 09:11 AM
