1. AC Question's Avatar
    Hi,
    I have been trying to root my S7 Edge (G935F) using Odin and Chainfire, and whenever I go through the entire process (Odin says "Pass"), my device freezes at the booting screen. Normally, when my phone boots it vibrates once and after the Samsung Logo my carrier logo (Three mobile) is displayed. After that the phone boots into Android. Now, when I root the device, every time it reaches the "Three mobile" logo it vibrates twice and won't proceed anywhere from there. The only way to make it boot is to restore my phone to factory defaults and wipe all data. Any ideas?
    05-18-2017 04:21 PM
  2. underway99's Avatar
    The bootloader appears to be starting the device, but you've described the phone hanging when the OS loads. The SM-G935F has a lot of local/regional versions. It sounds like you either didn't get the correct firmware for your device and region, or your firmware download was corrupted.
    I'd recommend that you start over with a fresh copy of the firmware, verifying that you have the correct one for where you're going to use the phone.
    05-20-2017 09:29 PM
  1. My Samsung just updated - and I hate it. Can it go back?
    Last Post: 06-20-2017, 02:20 PM
  2. I cant get pass my screen because it is asking for a password
    Last Post: 05-18-2017, 04:42 PM
  3. Why can't I see my app icon?
    Last Post: 05-18-2017, 04:26 PM
  4. can the retractable ear piece be fixed on LG HBS 810
    Last Post: 05-18-2017, 03:47 PM
  5. How to send/extract Samsung S7 and S7 edge Slow Motion video?
    Last Post: 05-18-2017, 02:25 PM
