1. widget10's Avatar
    ill start from the beginning, my s7 edge has been rooted for a while with no issues then my battery started taking a while to charge even on fast charge so I thought id put it back to stock so I plugged it into my pc and all it would do Is charge so I tried a few things after googling etc I turned debugging off then back on but everything I tried didn't work so I thought ill turn the phone off then back on wish I hadn't now it comes up with "custom binary blocked by frp lock" in red at top of phonei can get it into odin mode but when I connect the usb it does nothing please help all advice will be gratefully received thanks in advance.
    11-04-2017 07:08 AM
  2. B. Diddy's Avatar
    Moved to the S7 edge Rooting forum.
    11-05-2017 01:57 AM
  1. Why in my phone why this statment come invalid input
    Last Post: 12-24-2017, 01:28 PM
  2. why my samsung galaxy S7 edge is not compatible with Asphalt 8
    Last Post: 12-03-2017, 11:24 PM
  3. Huawei P9 Lite - Vanishing files and folders
    Last Post: 11-05-2017, 01:03 AM
  4. Help me
    By Mudith Pravin in forum Ask a Question
    Last Post: 11-04-2017, 07:49 AM
  5. Replies: 0
    Last Post: 11-04-2017, 06:18 AM
