    I've tried installing custom roms on my exynos s7 edge for a week now. the fact is, running geekbench shows that multi core performance drops to below 4k, whereas in the official oreo updates it was about 5.9k, and in most of the cases, the camera disturbs, or google account sign in doesn't work. so is there any stock rom with little to no compromise???
    12-28-2018 01:38 AM
  2. Rukbat's Avatar
    There's only 1 stock ROM for each version for each phone. Any other ROM is a custom ROM.
    Some custom ROMs may run faster than the stock ROM for certain things, but the best ROM, just for overall performance, is always the stock ROM. Which one? That depends on the model of S7E - Exynos is used in more than one. Look on https://www.sammobile.com/firmwares/. Put in the S7 Edge, find your phone's model (then scroll down), find the one for your country/carrier and use that one.
    12-28-2018 06:46 PM
  1. S6 Edge battery drains when there are pending PlayStore updates
    By Android Central Question in forum Samsung Galaxy S6 edge
    Last Post: 12-27-2018, 08:42 PM
  2. Calender for J7 samsung has no holidays
    Last Post: 12-27-2018, 06:37 PM
  3. S6 Edge battery drains when there are pending PlayStore updates
    Last Post: 12-27-2018, 06:19 PM
