07-27-2016 02:26 PM
150 1234 ...
tools
  1. recDNA's Avatar
    S6 had it too. Thinking of picking up a s6 refurb. Nothing in new model appeals to me as much as loss of ir blaster. I have one in gear 2 but the software only allows 1 tv at a time and has very limited options. On Off volu and channel are about it.
    02-20-2016 01:30 PM
  2. sdsubball23's Avatar
    Can't you use bluetooth instead to control a tv if the tv has that feature?
    02-20-2016 01:51 PM
  3. recDNA's Avatar
    No. I control random tvs in restaurants and bars i visit. They often don't mind if I ask. One place has a tv at every table but all different brands of tv. They don't have all the remotes. I also control an ac I lost the remote for and when wife has remote at home i use phone. Many many uses for ir blaster. I also use it at work to control several different presentation projectors.
    02-20-2016 02:18 PM
  4. anon(9408097)'s Avatar
    In that one hour you spent with it, does it feel like a worthy upgrade? Yes or no?
    02-20-2016 02:41 PM
  5. bmanzella527's Avatar
    The phone feels solid. It's definitely a upgrade. I think for me, the battery life is a significant difference. S7 edge will have note like battery.
    Camera is best on the market.
    Has a sd card slot.
    Water resistance.
    Better battery life.
    More premium feel.
    If those appeal to you it's a worthy upgrade
    02-20-2016 03:42 PM
  6. barondebxl's Avatar
    Well tell us your thoughts
    02-20-2016 04:02 PM
  7. ThrottleJohnny's Avatar
    Does Touchwiz feel any lighter? Were you able to test the speakers?
    02-20-2016 04:12 PM
  8. lindseybp's Avatar
    Do the cameras have OIS??
    02-20-2016 04:18 PM
  9. bmanzella527's Avatar
    Speakers were decent. Slightly better than the s6.
    Touch wiz is better but I'm not a fan of the white motivation toggles.
    02-20-2016 04:22 PM
  10. AlphaWlf6's Avatar
    Neither of the S7 have usb c even tho it is a convenient. No single manufacturer actually takes advantage of the data to transfer speeds or the charging type c is known for. Plus makes it easier for gear Vr use.
    The device is not 5.7 in it is 5.5in
    Multi color led yes and IR no. Most tvs have smart apps now or apps for cable providers or game consoles.
    02-20-2016 04:46 PM
  11. AlphaWlf6's Avatar
    Speakers are alot better the devices does have OIS and ip68
    02-20-2016 04:48 PM
  12. sam00's Avatar
    When you say it feels heavier does that mean it's thicker?
    02-20-2016 04:49 PM
  13. PowrDroid's Avatar
    Does it have wireless charging?
    Tell us about the fingerprint scanner.
    02-20-2016 04:49 PM
  14. AlphaWlf6's Avatar
    Does have wireless charging. Both standards. Fingerprint scanner is a bit larger however alot faster. And the device is a little bit thicker but a lot less camera bump. And the curved back makes it feel better in hand.
    02-20-2016 04:59 PM
  15. bmanzella527's Avatar
    It's slightly thicker but it feels way more dense. It's like they jam packed the whole device and there is no empty space on the inside.
    02-20-2016 05:06 PM
  16. PsychDoc's Avatar
    the device is not 5.7 in it is 5.5in
    posted via the android central app
    yay!!!!!
    I'm getting it then.
    Thanks for the update
    02-20-2016 05:07 PM
  17. Almeuit's Avatar
    I will say the 3A charging on the 6P is pretty awesome. Goes pretty quick .
    02-20-2016 05:23 PM
  18. anon(52425)'s Avatar
    Wondering... How did you guys obtain the devices and how long has it been?
    02-20-2016 05:26 PM
  19. shiggins316's Avatar
    No usb c is unfortunate. It's so easy. My kid broke my s6 edge plus trying to charge it. Wouldn't of happened with usb c. Is the battery removable?
    02-20-2016 06:00 PM
  20. delta7's Avatar
    Crap, it'd heavier.
    Same thing apple did with the 6 compared to 6s.
    Crap,
    Crap, seriously that's crap.
    A fat dude like me like my phone light So I can get it out of my Jeans since my gut hangs in the way.
    Gotta hit the gym.
    norbl likes this.
    02-20-2016 06:10 PM
  21. bmanzella527's Avatar
    No
    shiggins316 likes this.
    02-20-2016 06:39 PM
  22. anon(5630457)'s Avatar
    Had about a hour with the phone today. Have full breakdown about all of the aspects of the phone.
    Any questions?
    How did you get access to it?
    02-20-2016 06:55 PM
  23. bmanzella527's Avatar
    I can't speak on that since it could affect someone's job
    02-20-2016 07:02 PM
  24. Devil13n's Avatar
    5.5?
    I'm out.
    02-20-2016 08:01 PM
  25. PsychDoc's Avatar
    5.5?
    I'm out.
    What were you hoping for, 5.7"?
    If you want that, get the Note. For me that's just too big. 5.5" was what I was waiting for for a while. I'm super psyched.
    EMGSM likes this.
    02-20-2016 08:43 PM
150 1234 ...
  1. Replies: 1
    Last Post: 02-20-2016, 04:51 PM
  2. Super bad battery life on lg g2
    Last Post: 02-20-2016, 05:49 AM
  3. Replies: 0
    Last Post: 02-20-2016, 02:02 AM
  4. Replies: 0
    Last Post: 02-20-2016, 01:40 AM
  5. Replies: 0
    Last Post: 02-20-2016, 12:38 AM
