1. Golfdriver97's Avatar
    About the internal cooling system in the S7? I think it's a pretty good idea.
    02-21-2016 12:33 PM
  2. whtchdr's Avatar
    I'll be curious to see how much it lowers operating temps at load. Should definitely help with sweaty gamer hand syndrome...lol
    02-21-2016 02:40 PM
  3. OceanView's Avatar
    Sounds really cool but how much of a difference will it really make?
    02-21-2016 06:08 PM
  4. Cakefish's Avatar
    I think it sounds really cool... pun intended.
    02-21-2016 06:46 PM
  5. Alex Wetzel's Avatar
    I think it will help not only when the CPU is under load, but also with lag and stutter in the UI (hopefully)
    Posted from the one and only Note 4
    02-21-2016 06:52 PM
  6. erwaso's Avatar
    It's actually pretty fancy. Looking forward to see how well it functions since I mobile game a lot
    02-22-2016 02:24 AM
  7. zipro's Avatar
    I'm pretty sure it won't leak, if that's what you mean :-)
    However, it also probably isn't very effective. The Lumia 950 range comes with liquid cooling and it apparently doesn't fix the heat issues.
    02-22-2016 03:49 AM
  8. Cakefish's Avatar
    Snapdragon 810 though
    02-22-2016 04:13 AM
  9. RichBrown68's Avatar
    I'm thinking one of the big benefits of this will be for those using Samsung gear VR headsets. There's an issue when you use it for very long, the phone overheats and you get a message saying to give the headset a break and allow it to cool down.
    02-22-2016 07:52 AM
  10. rushmore's Avatar
    I would be surprised if Samsung at least tried beyond marketing hype, since they want to push Gear VR use and the previous devices simply get too hot. Not sure how much they can do though. Small device footprint and same nM chip, but even faster. Interesting.
    02-22-2016 11:46 AM
  11. Zendroid1's Avatar
    Omg Samsung so stole this from the Lumia 950xl!
    02-22-2016 02:06 PM
  1. Read this before upgrading to Marshmallow, things that you should know.
    By Toltepeceno Delsur in forum Android 6.0 Marshmallow
    Last Post: 06-28-2016, 07:06 PM
  2. Replies: 1
    Last Post: 03-04-2016, 08:11 AM
  3. S2 Gear watch with S7 Edge from Verizon?
    By PsychDoc in forum Samsung Galaxy S7 edge
    Last Post: 02-26-2016, 10:26 AM
  4. Replies: 0
    Last Post: 02-26-2016, 10:15 AM
