02-27-2016 09:32 PM
125 123 ...
tools
  1. anon(9408097)'s Avatar
    10 points to anyone who can point out something wrong with this phone.
    Except touchwiz
    02-21-2016 04:14 PM
  2. Mdbills484's Avatar
    32 bit audio? Don't think so.
    02-21-2016 04:28 PM
  3. azie's Avatar
    I didn't see the Led notification. Is there?
    02-21-2016 04:30 PM
  4. azie's Avatar
    Storage for pictures and different files like music or pdfs is not good at all?
    02-21-2016 04:39 PM
  5. DakotaBoy's Avatar
    32 bit audio.
    Does that affect bluetooth or sonos streaming, or just wired headphones?
    02-21-2016 05:23 PM
  6. RN50's Avatar
    No front facing speakers?? Should also be a 64gb option. Personally don't give a monkeys about SD cards.
    alhc78 and MarqBland like this.
    02-21-2016 05:25 PM
  7. Mdbills484's Avatar
    32 bit audio.
    Only headphones
    02-21-2016 05:27 PM
  8. PowerThroughLove's Avatar
    It seems a very common complaint with Galaxy phones is they become significantly slower as time goes on. I wonder if that is fixed.
    getdez likes this.
    02-21-2016 05:49 PM
  9. Cakefish's Avatar
    64GB option confirmed for select regions:
    RN50 likes this.
    02-21-2016 06:50 PM
  10. torbach1's Avatar
    https://uploads.tapatalk-cdn.com/2016...347294abc0.jpg
    They would be really stupid not to bring that option to the US. But they've been known to occasionally do stupid things like not releasing the Note 5 in Europe.
    02-21-2016 07:00 PM
  11. torbach1's Avatar
    Except touchwiz
    If I can get a version of the Edge that's not tied to AT&T's Byzantine release schedule even for security updates, I may consider it.
    02-21-2016 07:01 PM
  12. anon(5630457)'s Avatar
    No need for it with always-on display.
    02-21-2016 07:22 PM
  13. dplane's Avatar
    I'm excited. This will be my first Samsung phone since starting with Android on the original Droid. I really tried very hard to not become a Galaxy sheep (No offense) but there really is too much goodness going on here to not try it. Especially the cam improvements, even though the G4 has served me well in that regard, will be very nice for snapping shots of the little one. Done with LG after all the hardware issues though. Hopefully better luck with Sammy.
    02-21-2016 07:53 PM
  14. Mike-Mike's Avatar
    With the 4GB of RAM and that battery, seems like a winner to me
    02-21-2016 08:17 PM
  15. meyerweb#CB's Avatar
    Have to disagree with that. The LED can be much more easily seen from a distance, like across the room.
    race4life, Llmgtab99 and Jadaress like this.
    02-21-2016 09:15 PM
  16. Cakefish's Avatar
    AOD consumes less than 5% over a 10 hour period.
    02-21-2016 09:56 PM
  17. anon(9408097)'s Avatar
    So none of you have won the 10 points yet.
    32 bit audio? Maybe. And no front facing speakers? That's lacking, yes but the audio coming from the mono speaker isn't "wrong" or bad by any means.
    I'll give the speakers issue 3 points that's it. I have the S6 edge and I've never felt the need for front facing speakers to be honest even though I've owned the one m8 in the past.
    This is really surprising :o
    02-22-2016 04:23 AM
  18. anon(9408097)'s Avatar
    And there has to be a notification led! There will be don't worry about that. If there isn't I'll give everybody 10 points here because I think that's an important feature despite of having the always on display.
    02-22-2016 04:24 AM
  19. flintlock's Avatar
    Still can't easily swap the battery. Lithium batterys degrade after about 200 charge cycles. Iphones can have it replaced at a store even though it's expensive and they have to turn their data over to a stranger.
    Isn't Samsung's only solution that you mail it in. Will a do it yourself option be possible?
    02-22-2016 05:09 AM
  20. Dave Wong's Avatar
    Lack of timely Android updates (especially when you factor in the carriers), but that's going to be the case with any non-Nexus phone.
    02-22-2016 05:30 AM
  21. Cakefish's Avatar
    Luckily Marshmallow is waaay more optimised than Lollipop so the wait for N won't be as bad as it has been waiting for Marshmallow.
    02-22-2016 05:42 AM
  22. Nakrohtap's Avatar
    Why is everyone mentioning 32 bit audio as a bad thing? CD audio is 16 bit and HD audio is 24 bit. Bit depth is different than bit rate.
    Not Quite Right likes this.
    02-22-2016 06:06 AM
  23. icellphones32's Avatar
    No iR blaster
    02-22-2016 08:08 AM
  24. anon(9408097)'s Avatar
    I guess this could earn the 10 points. But we still have to wait for this to happen. Certainly applies to the S6 line up. Poorly managed updates. Samsung really dropped the ball there.
    02-22-2016 08:10 AM
  25. anon(9408097)'s Avatar
    No iR blaster
    I guess that's it! Haha you get 10 points! I understand that not many people use the IR blaster but it is missing alright! They shouldn't have excluded it. Well I guess the S7 isn't perfect after all.
    02-22-2016 08:16 AM
125 123 ...
  1. How much bloatware is on the S7?
    By AC Question in forum Samsung Galaxy S7
    Last Post: 03-08-2016, 08:49 AM
  2. S7 - Fast Charger for $39.99
    By ihtc in forum Samsung Galaxy S7
    Last Post: 02-23-2016, 09:58 PM
  3. I can't restore my HTC One M9 to its original settings
    By AC Question in forum HTC One M9
    Last Post: 02-23-2016, 02:14 PM
  4. How much bloatware is on the S7?
    Last Post: 02-23-2016, 11:39 AM
  5. I can't restore my HTC One M9 to its original settings
    Last Post: 02-23-2016, 11:33 AM
