1. Mike-Mike's Avatar
    The 3600 in the edge is Droid MAXX/Turbo level right?
    This the biggest battery Sammy has ever had, I think
    I know some off brands have bigger batteries, but for the main players, this is the biggest one out right?
    02-21-2016 09:16 PM
  2. T48's Avatar
    I was thinking S6 Active, but just looked & it was 3500 mAh.
    02-21-2016 09:38 PM
  3. dpham00's Avatar
    Droid turbo was 3900mah.
    The am7 had 4100mah
    02-21-2016 09:47 PM
  4. meyerweb#CB's Avatar
    http://www.amazon.com/Zerolemon-1000...cUvbUpU5008027
    Zerolemon 10,000 mAh! (Yes, I know it's not OEM.)
    02-21-2016 10:20 PM
  5. Mike-Mike's Avatar
    What is the am7?
    02-21-2016 11:16 PM
  6. Mike-Mike's Avatar
    The am7 had 4100mah
    I just looked them up and you are right.
    apparently I was thinking the original Droid MAXX which had 3500
    Droid Turbo was a beast with 3900
    For some reason Droid Turbo 2 dropped down to 3760.
    Still 3600 and Doze should be pretty solid on the Edge
    02-21-2016 11:20 PM
  7. SactoKingsFan's Avatar
    Zuk z1 has 4100 mAh battery.
    02-21-2016 11:29 PM
  8. mohit9206's Avatar
    Asus Zenfone Max has 5000mah battery. Its not one of the top brands but its pretty well known brand.
    02-21-2016 11:30 PM
  9. dpham00's Avatar
    What is the am7?
    Huawei ascend mate 7.
    02-21-2016 11:48 PM
  10. erwaso's Avatar
    3600 is big. Hopefully it lasts longer and not just was needed to power the phone enough to last.
    02-22-2016 03:31 AM
  11. Mike-Mike's Avatar
    anyone have the S6 Edge+ ? how is the battery life on that?
    02-22-2016 08:18 AM
  12. dpham00's Avatar
    It was roughly the same as my note 5. Which is to say way better than the s6/e
    02-22-2016 03:21 PM
  1. what does the different color icons on my contacts mean
    Last Post: 04-01-2016, 09:13 AM
  2. Replies: 1
    Last Post: 02-21-2016, 11:21 PM
  3. Replies: 1
    Last Post: 02-21-2016, 11:15 PM
  4. adjust galaxy nexus screen sensitivity
    Last Post: 02-21-2016, 11:13 PM
  5. Replies: 1
    Last Post: 02-21-2016, 11:05 PM
