rechvanny
What swiping? are you talking about all you tabs showing up separately?
If so you can fix that.
Here's how you bring Chrome tabs back into the app and out of your recent apps screen:
Open Chrome
Open its menu by tapping on the three little dots in the upper corner
Hit Settings
Open "Merge tabs and apps" and switch it to "Off"
How to remove Chrome tabs from your recent apps list (Android 5.0 Lollipop guide)
No, I'm not talking about the Chrome "merge tabs and apps" thing... I've already switched that off as soon as I opened Chrome. I'm bugged more about the not-so-smooth or the not-so-sensitive swiping away apps in the recent tasks/open apps rolodex UI. It sometimes translates swipe away as tapping so it opens the app in the foreground instead of "closing" it.
